Trouble setting up stream component
I am trying to add the stream component to hass, for connecting my RTSP-enabled doorbell.
After adding it to the configuration.yaml, the error log shows:
Setup failed for stream: Requirements for stream not found: ['av==6.1.2'].
According to https://www.home-assistant.io/integrations/stream/#troubleshooting, this issue can be fixed by installing the right dependencies:
sudo apt-get install -y python-dev pkg-config libavformat-dev libavcodec-dev libavdevice-dev libavutil-dev libswscale-dev libavresample-dev libavfilter-dev
However, this command fails with:
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/libv/libvpx/libvpx5_1.7.0-3_armhf.deb  404  Not Found
I can confirm the link is indeed dead, so it appears that there is an issue with my package repo in Raspbian.
I am running Raspbian Buster on a Pi 4 (virtualenv). To be precise:
uname -a
Linux raspberrypi 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux
Anyone here who encountered the same problems and managed to fix it?
I already tried to install ffmpeg and others from source, but this did not help much.
