Hey, I just started using home assistant about a month ago. I’ve gotten a hang of the UI but anything having to do with the the config just doesn’t work out
So far I’ve wanted to add virtual components to my dashboard but can’t seem to get it to work. I’ve downloaded the virtual repo, now I just have to add instances to the my config but it just doesn’t work.
I’ve followed all the instructions in the README but I can’t just get it to work.
Here’s my config. I just want to create a simple light instance for starters.
What should I add to this file that you think would create the entity, or doesn’t this create an entity?
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
Also setting a static image as the themes background has proven impossible.
Please Help!!
