I’ve been having some trouble starting some add-ons. Sepcifically Let’s Encrypt and Check Homeassistant config.
Basically, let’s just use Let’s Encrypt, I go into the add-on. I make sure my settings are correct. I press the Start button. I check the logs and see that I do not need to renew my cert - OK. Everything should be good, but when I leave the Let’s Encrypt page, and go back to it, Let’s Encrypt has stopped and I have to start it again. This constantly happens, and it’s not doing what it’s supposed to (I cannot access my HA outside of my network).
I’ve tried uninstalling it and reinstalling it. But I’ve had no luck at all. Any idea? I’ve got 443 and 80 port open, but since this is also happening on another add-on, I don’t think it’s a settings problem.
