Hi: here is my configuration.yaml
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: 43.6313
longitude: -79.7148
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 190
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: America/Toronto
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
# Uncomment this to add a password (recommended!)
# api_password: PASSWORD
# Uncomment this if you are using SSL or running in Docker etc
# base_url: example.duckdns.org:8123
# Checks for available updates
updater:
# Discover some devices automatically
discovery:
#Broadlink RM 3
switch:
- platform: broadlink
host: 192.168.85.129
mac: 'b4:43:0d:f9:20:fd'
type: rm_mini
timeout: 15
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time.
history:
# View all events in a logbook
logbook:
# Track the sun
sun:
# Weather Prediction
platform: yr
# Text to speech
tts:
platform: google
group: !include groups.yaml
and I keep getting error
←[31m17-09-08 23:30:57 ERROR (<concurrent.futures.thread.ThreadPoolExecutor obje
ct at 0x0000000003B4EBE0>_2) [homeassistant.util.yaml] while scanning for the ne
xt token
found character ‘\t’ that cannot start any token
in “B:\Users\yyandjj\AppData\Roaming.homeassistant\configuration.yaml”, line
42, column 1←[0m
←[31m17-09-08 23:30:57 ERROR (MainThread) [homeassistant.components] while scann
ing for the next token
42, column 1←[0m
Please help
