I have HA installed on a Raspberry Pi 3 using the AIO installer. I tried both update methods here (fabric and manually). Here’s a copy of my manual SSH:
pi@raspberrypi:~ $ sudo su -s /bin/bash hass
hass@raspberrypi:/home/pi$ source /srv/hass/hass_venv/bin/activate
(hass_venv) hass@raspberrypi:/home/pi$ pip3 install --upgrade homeassistant
Both methods gave me connection errors like this:
Retrying (Retry(total=3, connect=None, read=None, redirect=None)) after connection broken by ‘New ConnectionError(’<pip._vendor.requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x7600b0b0>: Failed to establish a new connection: [Errno -2] Name or service not known’,)': /simple/homeassistant
Furthermore, I’m thinking the cause has also caused other problems in my home assistant configuration. For example, I wasn’t able to get pushbullet to work. It gave me a bootstrap error, so I just removed that from my config for the time being. Now I’m getting a bootstrap error for nmap_tracker. Here are my current errors in HA:
16-09-14 14:44:46 homeassistant.components.updater: Could not contact PyPI to check for updates
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connection.py", line 142, in _new_conn
(self.host, self.port), self.timeout, **extra_kw)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/util/connection.py", line 75, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/lib/python3.4/socket.py", line 530, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -2] Name or service not known
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 595, in urlopen
chunked=chunked)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 352, in _make_request
self._validate_conn(conn)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 831, in _validate_conn
conn.connect()
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connection.py", line 254, in connect
conn = self._new_conn()
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connection.py", line 151, in _new_conn
self, "Failed to establish a new connection: %s" % e)
requests.packages.urllib3.exceptions.NewConnectionError: <requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x7375dbf0>: Failed to establish a new connection: [Errno -2] Name or service not known
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/adapters.py", line 423, in send
timeout=timeout
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 640, in urlopen
_stacktrace=sys.exc_info()[2])
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/util/retry.py", line 287, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
requests.packages.urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='pypi.python.org', port=443): Max retries exceeded with url: /pypi/homeassistant/json (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x7375dbf0>: Failed to establish a new connection: [Errno -2] Name or service not known',))
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/updater.py", line 47, in get_newest_version
req = requests.get(PYPI_URL)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/api.py", line 70, in get
return request('get', url, params=params, **kwargs)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/api.py", line 56, in request
return session.request(method=method, url=url, **kwargs)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/sessions.py", line 475, in request
resp = self.send(prep, **send_kwargs)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/sessions.py", line 596, in send
r = adapter.send(request, **kwargs)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/adapters.py", line 487, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='pypi.python.org', port=443): Max retries exceeded with url: /pypi/homeassistant/json (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x7375dbf0>: Failed to establish a new connection: [Errno -2] Name or service not known',))
16-09-14 14:47:16 homeassistant.bootstrap: Not initializing device_tracker.nmap_tracker because could not install dependency python-nmap==0.6.1
16-09-14 14:47:18 homeassistant.components.recorder: Ended unfinished session (id=91 from 2016-09-14 18:41:27.900057)
16-09-14 14:47:18 homeassistant.components.recorder: Found unfinished sessions
Please let me know if you have any ideas!
