I can’t upgrade to core 2023.10.3. Help needed. This is what I see on the supervisor logs:
23-10-18 06:29:43 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-10-18 06:30:45 INFO (MainThread) [supervisor.homeassistant.core] Updating Home Assistant to version 2023.10.3
23-10-18 06:30:45 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2023.10.2 to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2023.10.3
23-10-18 06:30:45 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2023.10.3.
23-10-18 06:30:46 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2023.10.3: 500 Server Error for http+docker://localhost/v1.43/images/ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2023.10.3/json: Internal Server Error ("readlink /mnt/data/docker/overlay2: invalid argument")
23-10-18 06:30:46 WARNING (MainThread) [supervisor.homeassistant.core] Updating Home Assistant image failed
Here’s my About
Home Assistant 2023.10.2
Supervisor 2023.10.0
Operating System 11.0
Frontend 20231005.0 - latest
