Hi, ive got a fresh build of 2.8.1 from the all in one installer and have run the command to upgrade the rebooted but the version is still 2.8.1. what am I doing wrong?
pi@raspberrypi:~ $ sudo pip3 install --upgrade homeassistant
Downloading/unpacking homeassistant
Downloading homeassistant-0.28.2-py2.py3-none-any.whl (6.2MB): 6.2MB downloaded
Requirement already up-to-date: pyyaml>=3.11,<4 in /usr/local/lib/python3.4/dist-packages/PyYAML-3.12-py3.4-linux-armv7l.egg (fro m homeassistant)
Downloading/unpacking voluptuous==0.9.2 (from homeassistant)
Downloading voluptuous-0.9.2.tar.gz
Running setup.py (path:/tmp/pip-build-t3sjyjmz/voluptuous/setup.py) egg_info for package voluptuous
WARNING: Could not locate pandoc, using Markdown long_description.
Downloading/unpacking pip>=7.0.0 (from homeassistant)
Downloading pip-8.1.2-py2.py3-none-any.whl (1.2MB): 1.2MB downloaded
Requirement already up-to-date: pytz>=2016.6.1 in /usr/local/lib/python3.4/dist-packages/pytz-2016.6.1-py3.4.egg (from homeassistant)
Downloading/unpacking requests>=2,<3 from https://pypi.python.org/packages/ea/03/92d3278bf8287c5caa07dbd9ea139027d5a3592b0f4d14abf072f890fab2/requests-2.11.1-py2.py3-none-any.whl#md5=b4269c6fb64b9361288620ba028fd385 (from homeassistant)
Downloading requests-2.11.1-py2.py3-none-any.whl (514kB): 514kB downloaded
Downloading/unpacking typing>=3,<4 (from homeassistant)
Downloading typing-3.5.2.2.tar.gz (51kB): 51kB downloaded
Running setup.py (path:/tmp/pip-build-t3sjyjmz/typing/setup.py) egg_info for package typing
Downloading/unpacking jinja2>=2.8 (from homeassistant)
Downloading Jinja2-2.8-py2.py3-none-any.whl (263kB): 263kB downloaded
Downloading/unpacking setuptools>=0.6b1 from https://pypi.python.org/packages/2d/76/bce013588c82099ea243241441364db1e55a8d2d1a7cc962cee8873ccaea/setuptools-27.1.2-py2.py3-none-any.whl#md5=5f5be1c83ef30979bb1bf0ed3cb2b417 (from voluptuous==0.9.2->homeassistant)
Downloading setuptools-27.1.2-py2.py3-none-any.whl (464kB): 464kB downloaded
Requirement already up-to-date: MarkupSafe in /usr/lib/python3/dist-packages (from jinja2>=2.8->homeassistant)
Installing collected packages: homeassistant, voluptuous, pip, requests, typing, jinja2, setuptools
Running setup.py install for voluptuous
Found existing installation: pip 1.5.6
Not uninstalling pip at /usr/lib/python3/dist-packages, owned by OS
Found existing installation: requests 2.4.3
Not uninstalling requests at /usr/lib/python3/dist-packages, owned by OS
Running setup.py install for typing
Found existing installation: Jinja2 2.7.3
Not uninstalling Jinja2 at /usr/lib/python3/dist-packages, owned by OS
Found existing installation: setuptools 5.5.1
Not uninstalling setuptools at /usr/lib/python3/dist-packages, owned by OS
Successfully installed homeassistant voluptuous pip requests typing jinja2 setuptools
Cleaning up...
pi@raspberrypi:~ $ sudo reboot
