Trouble using a field in a script
I have a field in my script :
  fan_mode:
    selector:
      select:
        options:
          - auto
          - high
          - low
          - medium
    description: Fan speed
    default: auto
    example: high
    required: false
Now I want to check if this field is equal to an attribute of my aircon, but that seems not to be the correct syntax…what am I missing ?
                    if:
                      - condition: template
                        value_template: >-
                          {{ fan_mode !=
                          state_attr('climate.airco_living_links', 'fan_mode')
                    then:
                      - delay:
                          hours: 0
                          minutes: 0
                          seconds: 15
                          milliseconds: 0
                      - service: climate.set_fan_mode
                          fan_mode: "{{ fan_mode }}"
                          entity_id: climate.airco_living_links
that’s the correct syntax, how are you calling the script?
Default does not populate the variable with a default value. So do not assume that.
Sorry, seems indeed working :shushing_face:
