I have an automation that triggers from the home assistant complication on my watch. There are two switches that are being controlled. The first time the action is pressed, both switches should come on. The second time it’s pressed, one of them (bedside_lamp) turns off. The third time it’s pressed, the second (wild2) turns off and the first one (bedside_lamp) turns back on. The fourth time it’s pressed, both come on and the cycle restarts.
An input number (scent_increment) tracks the cycle iteration. It’s defined with min=0, max=4, step=1, default=1.
For the most part, this automation is working. The problem is when scent_increment == 1. Both switches correctly turn on, but the value doesn’t update (it should be set to 2, but it stays at 1). If I manually change the value to 2 on the front end, the automation proceeds correctly (that is, bedside_lamp turns off, scent_increment updates to 3). It also works correctly when scent_increment == 3.
Any thoughts??
- alias: Burst of Scent
- platform: event
event_type: ios.action_fired
event_data:
actionName: Burst of Scent
mode: restart
- data_template:
entity_id: >
{% if (states('input_number.scent_increment') | int) == 1 %}
switch.bedside_lamp, switch.wild2
{% elif (states('input_number.scent_increment') | int) == 2 %}
switch.wild2
{% else %}
switch.bedside_lamp
{% endif %}
service: homeassistant.turn_on
- data_template:
entity_id: >
{% if (states('input_number.scent_increment') | int) == 2 %}
switch.bedside_lamp
{% elif (states('input_number.scent_increment') | int) == 3 %}
switch.wild2
{% endif %}
service: homeassistant.turn_off
- service: input_number.set_value
entity_id: input_number.scent_increment
data_template:
value: >
{% if (states('input_number.scent_increment') | int) == 3 %}
1
{% else %}
{{ (states('input_number.scent_increment') | int) + 1 }}
{% endif %}
- delay: 0:30:00
- service: homeassistant.turn_off
entity_id:
- switch.bedside_lamp
- switch.wild2
value: 1
