Just finished manual installation of HA and all is working so far. Tried to install autostart as per tutorial and am receiving the following output from systemctl status:
pi@raspberrypi:~ $ sudo systemctl status home-assistant@hass -l
● [email protected] - Home Assistant for hass
Loaded: loaded (/etc/systemd/system/[email protected]; enabled)
Active: failed (Result: exit-code) since Sun 2016-10-02 15:05:56 UTC; 57s ago
Process: 645 ExecStart=/usr/bin/hass --runner (code=exited, status=217/USER)
Main PID: 645 (code=exited, status=217/USER)
Oct 02 15:05:56 raspberrypi systemd[1]: Started Home Assistant for hass.
Oct 02 15:05:56 raspberrypi systemd[1]: [email protected]: main process exited, code=exited, status=217/USER
Oct 02 15:05:56 raspberrypi systemd[1]: Unit [email protected] entered failed state.
pi@raspberrypi:~ $ journalctl -f -u home-assistant@hass
No journal files were found.
^C
@fabaff the problem ended up being that I had the wrong file path for hass for ExecStart . I found it with locate, as I did not have whereis installed.
Active: failed (Result: exit-code) since Mon 2016-12-26 19:44:57 UTC; 7s ago
Process: 12364 ExecStart=/srv/homeassistant/homeassistant_venv/bin/hass -c /hass/.homeassistant (code=exited, status=217/USER)
Main PID: 12364 (code=exited, status=217/USER)
Dec 26 19:44:57 raspberrypi systemd[1]: Started Home Assistant.
Dec 26 19:44:57 raspberrypi systemd[1]: [email protected]: main process exited, code=exited, status=217/USER
Dec 26 19:44:57 raspberrypi systemd[1]: Unit [email protected] entered failed state.
Active: failed (Result: exit-code) since Tue 2016-12-27 10:47:53 UTC; 4s ago
Process: 21128 ExecStart=/srv/homeassistant/homeassistant_venv/bin/hass -c /homeassistant/.homeassistant (code=exited, status=217/USER)
Main PID: 21128 (code=exited, status=217/USER)
Dec 27 10:47:53 raspberrypi systemd[1]: Started Home Assistant.
Dec 27 10:47:53 raspberrypi systemd[1]: [email protected]: main process exited, code=exited, status=217/USER
Dec 27 10:47:53 raspberrypi systemd[1]: Unit [email protected] entered failed state.
I am unsure when to use pi, hass, and homeassistant user profiles…
I also tried ‘sudo systemctl enable [email protected]’ etc but still got ‘No journal files were found’.
Perhaps I am best to give up and go for the all in one installer at this point…?
pi@raspberrypi:~ $ sudo systemctl status home-assistant@homeassistant
● [email protected]
Loaded: not-found (Reason: No such file or directory)
Active: inactive (dead)
pi@raspberrypi:~ $ sudo systemctl status home-assistant@pi
Active: failed (Result: exit-code) since Tue 2016-12-27 22:54:34 UTC; 7h ago
Process: 2996 ExecStart=/srv/homeassistant/homeassistant_venv/bin/hass -c /homeassistant/.homeassistant (code=exited, status=1/FAILURE)
Main PID: 2996 (code=exited, status=1/FAILURE)
Dec 27 22:54:33 raspberrypi systemd[1]: Started Home Assistant.
Dec 27 22:54:34 raspberrypi hass[2996]: Fatal Error: Specified configuration directory does not exist /homeassistant/…istant
Dec 27 22:54:34 raspberrypi systemd[1]: [email protected]: main process exited, code=exited, status=1/FAILURE
Dec 27 22:54:34 raspberrypi systemd[1]: Unit [email protected] entered failed state.
Hint: Some lines were ellipsized, use -l to show in full.
I wonder if I should be logged in as user homeassistant for this to work, but I do not know the password for this user (I get ‘Permissions denied’), and it is not the one I would have set had I been prompted to…
i think you should start again. you got all the name confused. In the first step in the autostart manual, you should put the [your user] as homeassistant if you install HA using the manual method.
$ su -c 'cat <> /etc/systemd/system/home-assistant@[your user].service
