Hi all, thanks in advance for the help!
I’m currently trying to get face recognition working via Facebox.
I have HA installed, along with Facebox and ESPHome, all as docker containers.
I’ve got myself an ESP32-CAM which i’ve setup in ESPHome, and it appears in Home Assistant.
It’s state is always “Idle” but it does show a very low frame-rate stream as expected when I click on the “More Info” button from “Developer Tools”.
I’ve got Facebox up-and-running, and taught it my face…
And i’ve added the entry for it in my configuration.yaml:
image_processing:
- platform: facebox
ip_address: 192.168.1.8
port: 8080
source:
- entity_id: camera.test_cam
In node-red (for convenience) I have a flow which calls the image_processing.scan
service, with the entity_id of camera.test_cam
Upon running the flow I get Unable to find referenced entities camera.test_cam
from helpers/service.py:130
in the logs.
I’ve updated HA, ESPHome and Facebox so they are all using the latest docker images.
Anyone have any ideas/thoughts on what could be going wrong?
