I am trying to install HomeAssistant on my Unraid server (intel) as a VM. It worked previously on the same server, but I had to reinstall Unraid and now need to rebuild Home Assistant. I can’t get it to run at all. When I go the homeassistant.local:8123, it says not found.
I’m using qcow2 version 13.1
Below it the VM configuration file. Further down is the log. What else is needed.
I have tried changing:
- Primary vDisk Bus from VirtIO to SATA
- Network Source from br0 to vibr0
Icon: Change Icon...
Autostart:
No
Name:
HASS
Description:
Home Assistant
CPU Mode:
Host Passthrough (12th Gen Intel® Core™ i5-12600K@)
Logical CPUs:
Initial Memory:
4096 MB
Max Memory:
4096 MB
Machine:
Q35-7.2
BIOS:
OVMF
Enable USB boot:
No
USB Controller:
2.0 (EHCI)
OS Install ISO:
Click and Select cdrom image to install operating system
Primary vDisk Location:
Manual
/mnt/user/domains/haos_ova-13.1.qcow2
Primary vDisk Bus:
VirtIO
Boot Order:
1
Primary Serial:
vdisk1
Unraid Share Mode:
9p Mode
Unraid Share:
Manual
Unraid Source Path:
e.g. /mnt/user/...
Unraid Mount Tag:
e.g. shares (name of mount tag inside vm)
Graphics Card:
Virtual
VM Console Protocol:
VNC
VM Console enable Copy/paste:
No
VM Console AutoPort:
Yes
VM Console Video Driver:
QXL (best)
VM Console Password:
password for VM Console (optional)
VM Console Keyboard:
English-United States (en-us)
Sound Card:
None
Network MAC:
52:54:00:ef:12:fe
Network Source:
br0
Network Model:
virtio-net
Boot Order:
Select Optional Boot Order
USB Devices:
Holtek Semiconductor Wired Keyboard (78/79 key) (04d9:0006)
Pixart Imaging Optical Mouse (093a:2510)
ASUSTek Computer AURA LED Controller (0b05:19af)
Intel Corp. (8087:0033)
Select Boot Order
Other PCI Devices:
None available
Homeassistant Log on Unraid VM
'''-device '{"driver":"pcie-root-port","port":10,"chassis":3,"id":"pci.3","bus":"pcie.0","addr":"0x1.0x2"}' \
-device '{"driver":"pcie-root-port","port":11,"chassis":4,"id":"pci.4","bus":"pcie.0","addr":"0x1.0x3"}' \
-device '{"driver":"pcie-root-port","port":12,"chassis":5,"id":"pci.5","bus":"pcie.0","addr":"0x1.0x4"}' \
-device '{"driver":"ich9-usb-ehci1","id":"usb","bus":"pcie.0","addr":"0x7.0x7"}' \
-device '{"driver":"ich9-usb-uhci1","masterbus":"usb.0","firstport":0,"bus":"pcie.0","multifunction":true,"addr":"0x7"}' \
-device '{"driver":"ich9-usb-uhci2","masterbus":"usb.0","firstport":2,"bus":"pcie.0","addr":"0x7.0x1"}' \
-device '{"driver":"ich9-usb-uhci3","masterbus":"usb.0","firstport":4,"bus":"pcie.0","addr":"0x7.0x2"}' \
-device '{"driver":"virtio-serial-pci","id":"virtio-serial0","bus":"pci.2","addr":"0x0"}' \
-blockdev '{"driver":"file","filename":"/mnt/user/domains/haos_ova-13.1.qcow2","node-name":"libvirt-1-storage","cache":{"direct":false,"no-flush":false},"auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-1-format","read-only":false,"cache":{"direct":false,"no-flush":false},"driver":"qcow2","file":"libvirt-1-storage","backing":null}' \
-device '{"driver":"virtio-blk-pci","bus":"pci.3","addr":"0x0","drive":"libvirt-1-format","id":"virtio-disk2","bootindex":1,"write-cache":"on","serial":"vdisk1"}' \
-netdev tap,fd=36,id=hostnet0 \
-device '{"driver":"virtio-net","netdev":"hostnet0","id":"net0","mac":"52:54:00:ef:12:fe","bus":"pci.1","addr":"0x0"}' \
-chardev pty,id=charserial0 \
-device '{"driver":"isa-serial","chardev":"charserial0","id":"serial0","index":0}' \
-chardev socket,id=charchannel0,fd=34,server=on,wait=off \
-device '{"driver":"virtserialport","bus":"virtio-serial0.0","nr":1,"chardev":"charchannel0","id":"channel0","name":"org.qemu.guest_agent.0"}' \
-device '{"driver":"usb-tablet","id":"input0","bus":"usb.0","port":"1"}' \
-audiodev '{"id":"audio1","driver":"none"}' \
-vnc 0.0.0.0:0,websocket=5700,audiodev=audio1 \
-k en-us \
-device '{"driver":"qxl-vga","id":"video0","max_outputs":1,"ram_size":67108864,"vram_size":67108864,"vram64_size_mb":0,"vgamem_mb":16,"bus":"pcie.0","addr":"0x1e"}' \
-device '{"driver":"virtio-balloon-pci","id":"balloon0","bus":"pci.4","addr":"0x0"}' \
-sandbox on,obsolete=deny,elevateprivileges=deny,spawn=deny,resourcecontrol=deny \
-msg timestamp=on
char device redirected to /dev/pts/0 (label charserial0)
qxl_send_events: spice-server bug: guest stopped, ignoring
2024-09-24T21:59:37.833679Z qemu-system-x86_64: terminating on signal 15 from pid 10372 (/usr/sbin/libvirtd)
2024-09-24 21:59:38.056+0000: shutting down, reason=shutdown
2024-09-24 22:06:20.778+0000: starting up libvirt version: 8.7.0, qemu version: 7.2.0, kernel: 6.1.99-Unraid, hostname: Tower
LC_ALL=C \
PATH=/bin:/sbin:/usr/bin:/usr/sbin \
HOME=/var/lib/libvirt/qemu/domain-2-HASS \
XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-2-HASS/.local/share \
XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-2-HASS/.cache \
XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-2-HASS/.config \
/usr/local/sbin/qemu \
-name guest=HASS,debug-threads=on \
-S \
-object '{"qom-type":"secret","id":"masterKey0","format":"raw","file":"/var/lib/libvirt/qemu/domain-2-HASS/master-key.aes"}' \
-blockdev '{"driver":"file","filename":"/usr/share/qemu/ovmf-x64/OVMF_CODE-pure-efi.fd","node-name":"libvirt-pflash0-storage","auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-pflash0-format","read-only":true,"driver":"raw","file":"libvirt-pflash0-storage"}' \
-blockdev '{"driver":"file","filename":"/etc/libvirt/qemu/nvram/b3b2f56d-3df9-5562-06d5-d65838b7b75c_VARS-pure-efi.fd","node-name":"libvirt-pflash1-storage","auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-pflash1-format","read-only":false,"driver":"raw","file":"libvirt-pflash1-storage"}' \
-machine pc-q35-7.2,usb=off,dump-guest-core=off,mem-merge=off,memory-backend=pc.ram,pflash0=libvirt-pflash0-format,pflash1=libvirt-pflash1-format \
-accel kvm \
-cpu host,migratable=on,host-cache-info=on,l3-cache=off \
-m 4096 \
-object '{"qom-type":"memory-backend-ram","id":"pc.ram","size":4294967296}' \
-overcommit mem-lock=off \
-smp 4,sockets=1,dies=1,cores=2,threads=2 \
-uuid b3b2f56d-3df9-5562-06d5-d65838b7b75c \
-no-user-config \
-nodefaults \
-chardev socket,id=charmonitor,fd=35,server=on,wait=off \
-mon chardev=charmonitor,id=monitor,mode=control \
-rtc base=utc,driftfix=slew \
-global kvm-pit.lost_tick_policy=delay \
-no-hpet \
-no-shutdown \
-boot strict=on \
-device '{"driver":"pcie-root-port","port":8,"chassis":1,"id":"pci.1","bus":"pcie.0","multifunction":true,"addr":"0x1"}' \
-device '{"driver":"pcie-root-port","port":9,"chassis":2,"id":"pci.2","bus":"pcie.0","addr":"0x1.0x1"}' \
-k en-us \
-msg timestamp=on
