Greetings,
I am attempting to utilize Node Red to alert me of the temperature if a given sensor is above or below a desired temperature with the cloud tts and google home speakers. I am currently utilizing the inject node to activate it while I attempt to get it working. I am utilizing the following flow:
[{"id":"60be9160.d8815","type":"tab","label":"TTS","disabled":false,"info":""},{"id":"7dabf8e3.27a638","type":"inject","z":"60be9160.d8815","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":75,"y":100,"wires":[["b7de34e3.dfd2b8"]],"l":false},{"id":"52f23ec3.3b5e2","type":"debug","z":"60be9160.d8815","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":830,"y":80,"wires":[]},{"id":"94e7b177.e7da2","type":"api-call-service","z":"60be9160.d8815","name":"TTS Bedroom Clock","server":"84a85f6b.8d261","version":3,"debugenabled":true,"service_domain":"tts","service":"cloud_say","entityId":"media_player.zach_s_bedroom_clock","data":"{\t \"message\":\"Bedroom Temperature is {{payload}}\",\t \"cache\":\"true\",\t \"language\":\"en-US\"\t}","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":720,"y":140,"wires":[["52f23ec3.3b5e2"]]},{"id":"b7de34e3.dfd2b8","type":"api-call-service","z":"60be9160.d8815","name":"Volume Set 40","server":"84a85f6b.8d261","version":3,"debugenabled":false,"service_domain":"media_player","service":"volume_set","entityId":"media_player.zach_s_bedroom_clock","data":"{\"volume_level\":0.1}","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":200,"y":100,"wires":[["8e62e35b.288c1"]]},{"id":"8e62e35b.288c1","type":"api-current-state","z":"60be9160.d8815","name":"","server":"84a85f6b.8d261","version":2,"outputs":1,"halt_if":"","halt_if_type":"num","halt_if_compare":"is","entity_id":"sensor.bedroom_temperature","state_type":"num","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":490,"y":80,"wires":[["52f23ec3.3b5e2","94e7b177.e7da2"]]},{"id":"b694691e.9ab048","type":"comment","z":"60be9160.d8815","name":"TTS Tester","info":"","x":120,"y":60,"wires":[]},{"id":"84a85f6b.8d261","type":"server","name":"Home Assistant","version":1,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
Every time I run it though it comes out saying “payload” or “message payload” rather than inserting the {{payload}} or {{msg.payload}}. I have tried several configurations and cannot seem to figure out how to get the service to work.
Pardon my formatting, I cant get the ``` to format it properly.
Any thoughts?
Thanks.
