Trouble with renewing a Let's Encrypt cert
I’m using Nginx Proxy Manager and DuckDNS on my HA setup. Recently, I was unable to login using myurl.duckdns.com, I could only get in using my Nabu Casa link. When trying to login I get an error that my SSL cert expired 02/10/22. But, when restarting DuckDNS or Nginx Proxy Manager they all say that my SSL cert is good until 04/12/22.
[14:27:03] INFO: Renew certificate for domains: myurl.duckdns.org
myurl2.duckdns.org and aliases:
# INFO: Using main config file /data/workdir/config
Processing myurl2.duckdns.org with alternative names: myurl.duckdns.org
 + Checking domain name(s) of existing cert... unchanged.
 + Checking expire date of existing cert...
 + Valid till Apr 12 14:12:52 2022 GMT (Longer than 30 days). Skipping renew!
Here is my DuckDNS config
lets_encrypt:
  accept_terms: true
  certfile: fullchain.pem
  keyfile: privkey.pem
  algo: secp384r1
token: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
domains:
  - myurl.duckdns.org
  - myurl2.duckdns.org
aliases: []
seconds: 300
I have two URLs because one points to my HA server and the other to my Blue Iris server.
Any idea how to correct this?
I stumbled upon the solution if anyone else has this issue. The SSL cert renewed but Nginx Proxy didn’t pick it up. I went into the Nginx proxy webUI, added a new SSL cert, which pulled the renewal through, then deleted the old cert.
