Trouble with self signed cerificate for SSL (dietpi/raspberry pi): setup failed, integration not found
Been following this Guide. I don’t need to access HA away from my network. Just need https so I can add smarthings integration.
I created keys with following command and placed them in homeassisant directory.
openssl req -sha256 -newkey rsa:4096 -nodes -keyout privkey.pem -x509 -days 730 -out certificate.pem
I then edited configuration.yaml and restarted homeassisant. I forwarded port 443 to 8123 tfor raspberry pi.
I then try to access it at https://localip:port
Configuration.yaml:
Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
ssl_certificate:
/mnt/dietpi_userdata/homeassistant/certificate.pem
ssl_key:
/mnt/dietpi_userdata/homeassistant/privkey.pem
Log:
21:16:08 ERROR (MainThread) [homeassistant.setup] Setup failed for ssl_certificate: Integration not found.
2019-05-21 21:16:09 ERROR (MainThread) [homeassistant.setup] Setup failed for ssl_key: Integration not found.
2019-05-21 21:16:10 ERROR (MainThread) [homeassistant.components.device_tracker] Unable to load /home/homeassistant
I can log in via http:// but not https://
Are you sure the user running home assistant has read access to the files and the directory they are in?
What type of installation? I find using Duckdns & LetsEncrypt work well together.
It’s running on dietpi. It’s the dietpi “optimized” version.
How do I check which user it’s installed under? At one point I tried changing users of those two files as suggested in the guide to dietpi and homeassisant and it didn’t make a difference.
Yeah I’ll switch to let’s encrypt/duckdns if it’s not a quick fix.
So I need a base url? I’ve tried different ones (local ip with/without port, with/without http or https, and my dyndns) and omitting it (since it’s not mentioned in the guide).
For an example, here is my configuration part for a Home Assistant venv installation.
http:
  base_url: xxx.duckdns.org:8123
  ssl_certificate: /home/homeassistant/dehydrated/certs/bwosborne.duckdns.org/fu
llchain.pem
  ssl_key: /home/homeassistant/dehydrated/certs/bwosborne.duckdns.org/privkey.pe
m
Spaces are important. When posting here, please follow this instruction.
HomeAss_CodeMarking_From%40finity
