I’m not sure if I’ve described the error I’m getting properly in the title so hopefully I can explain it a bit better.
I have 10 Sonoff devices functioning fine. Plugs, Switches, all OK. I had a Sonoff RF functioning fine but I upgraded the firmware and it stopped functioning, quite a while ago. It’s to receive signals from a PIR, some door sensors and some remotes. That part works fine now I have reflashed it with Tasmota (various versions, latest and old with the same results).
When I press a button on a remote, it’s supposed to toggle a switch within home assistant. This used to work fine but now doesn’t.
When connecting via SSH I can see the MQTT messages for the Sonoff/Tasmota switches when they are toggled just fine (using the command ‘hassio homeassistant logs’ I can see ‘2019-06-20 17:15:13 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on stat/sonoff10/RESULT: b’{“POWER”:“ON”}’
2019-06-20 17:15:13 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on stat/sonoff10/POWER: b’ON’). However… When I press a button on the remote, the console for the RF Bridge displays it’s seen it but no message is forwarded to Home Assistant.
When rebooting Home Assistant I get the message ‘[homeassistant.components.mqtt] Subscribing to stat/sonoff6/POWER’ for each of my devices but NOT for the RF Bridge. It’s as though it can’t see it properly?
MQTT settings are fine, I can see the device under the MQTT addon logs appearing fine with no errors. ‘1561047137: New client connected from 192.168.1.90 as DVES_8266F7 (c1, k15, u’homeassistant1’).’
I’ve tried setting a static IP and also leaving it at the one assigned by the router, no difference.
Console output from a working device -
00:00:00 Project sonoff Bedroom Lamp (Topic sonoff1, Fallback DVES_4F9F1E, GroupTopic sonoffs) Version 6.1.1-2_3_0
00:00:00 WIF: Connecting to AP1 DrayTek in mode 11N as sonoff1-7966…
00:00:03 WIF: Connected
00:00:03 DNS: Initialized
00:00:03 HTP: Web server active on sonoff1-7966.local with IP address 192.168.1.41
15:50:55 MQT: Attempting connection…
15:50:57 MQT: Connected
15:50:57 MQT: tele/sonoff1/LWT = Online (retained)
15:50:57 MQT: cmnd/sonoff1/POWER =
15:50:57 MQT: stat/sonoff1/RESULT = {“POWER”:“OFF”}
15:50:57 MQT: stat/sonoff1/POWER = OFF
15:50:57 MQT: tele/sonoff1/INFO1 = {“Module”:“Sonoff Basic”,“Version”:“6.1.1”,“FallbackTopic”:“DVES_4F9F1E”,“GroupTopic”:“sonoffs”}
15:50:57 MQT: tele/sonoff1/INFO2 = {“WebServerMode”:“Admin”,“Hostname”:“sonoff1-7966”,“IPAddress”:“192.168.1.41”}
15:50:57 MQT: tele/sonoff1/INFO3 = {“RestartReason”:“Software/System restart”}
15:50:57 MQT: homeassistant/light/sonoff1_1/config = (retained)
15:50:57 MQT: homeassistant/switch/sonoff1_1/config = {“name”:“Bedroom Lamp”,“command_topic”:“cmnd/sonoff1/POWER”,“state_topic”:“stat/sonoff1/RESULT”,“value_template”:"{{value_json.POWER}}",“payload_off”:“OFF”,“payload_on”:“ON”,“availability_topic”:“tele/sonoff1/LWT”,“payload_available”:“Online”,“payload_not_available”:“Offline”} (retained)
15:50:57 MQT: homeassistant/light/sonoff1_2/config = (retained)
15:50:57 MQT: homeassistant/switch/sonoff1_2/config = (retained)
15:50:57 MQT: homeassistant/light/sonoff1_3/config = (retained)
15:50:57 MQT: homeassistant/switch/sonoff1_3/config = (retained)
15:50:57 MQT: homeassistant/light/sonoff1_4/config = (retained)
15:50:57 MQT: homeassistant/switch/sonoff1_4/config = (retained)
15:50:57 MQT: homeassistant/light/sonoff1_5/config = (retained)
15:50:58 MQT: homeassistant/switch/sonoff1_5/config = (retained)
15:50:58 MQT: homeassistant/light/sonoff1_6/config = (retained)
15:50:58 MQT: homeassistant/switch/sonoff1_6/config = (retained)
15:50:58 MQT: homeassistant/light/sonoff1_7/config = (retained)
15:50:58 MQT: homeassistant/switch/sonoff1_7/config = (retained)
15:50:58 MQT: homeassistant/light/sonoff1_8/config = (retained)
15:50:58 MQT: homeassistant/switch/sonoff1_8/config = (retained)
15:50:59 MQT: stat/sonoff1/RESULT = {“POWER”:“OFF”}
15:50:59 MQT: stat/sonoff1/POWER = OFF
15:51:06 MQT: tele/sonoff1/STATE = {“Time”:“2019-06-20T15:51:06”,“Uptime”:“0T00:00:20”,“Vcc”:3.193,“POWER”:“OFF”,“Wifi”:{“AP”:1,“SSId”:“DrayTek”,“RSSI”:42,“APMac”:“00:1D:AA:6D:10:D0”}}
15:56:08 MQT: tele/sonoff1/STATE = {“Time”:“2019-06-20T15:56:07”,“Uptime”:“0T00:05:21”,“Vcc”:3.194,“POWER”:“OFF”,“Wifi”:{“AP”:1,“SSId”:“DrayTek”,“RSSI”:38,“APMac”:“00:1D:AA:6D:10:D0”}}
16:00:55 APP: Serial logging disabled
16:01:08 MQT: tele/sonoff1/STATE = {“Time”:“2019-06-20T16:01:08”,“Uptime”:“0T00:10:22”,“Vcc”:3.194,“POWER”:“OFF”,“Wifi”:{“AP”:1,“SSId”:“DrayTek”,“RSSI”:42,“APMac”:“00:1D:AA:6D:10:D0”}}
16:02:00 MQT: tele/sonoff1/UPTIME = {“Time”:“2019-06-20T16:02:00”,“Uptime”:“0T00:11:14”}
16:06:08 MQT: tele/sonoff1/STATE = {“Time”:“2019-06-20T16:06:08”,“Uptime”:“0T00:15:22”,“Vcc”:3.192,“POWER”:“OFF”,“Wifi”:{“AP”:1,“SSId”:“DrayTek”,“RSSI”:40,“APMac”:“00:1D:AA:6D:10:D0”}}
Console output from the RF Bridge -
00:00:00 APP: Set Baudrate to 19200
00:00:00 Project sonoff RF Bridge (Topic sonoff_rf, Fallback DVES_8266F7, GroupTopic sonoffs) Version 6.1.1-2_3_0
00:00:00 WIF: Connecting to AP1 DrayTek in mode 11N as sonoff_rf-1783…
00:00:03 HTP: Web server active on sonoff_rf-1783.local with IP address 192.168.1.90
00:00:05 MQT: Attempting connection…
00:00:06 MQT: Connected
00:00:06 MQT: tele/sonoff_rf/LWT = Online (retained)
00:00:06 MQT: cmnd/sonoff_rf/POWER =
00:00:06 MQT: tele/sonoff_rf/INFO1 = {“Module”:“Sonoff Bridge”,“Version”:“6.1.1”,“FallbackTopic”:“DVES_8266F7”,“GroupTopic”:“sonoffs”}
00:00:06 MQT: tele/sonoff_rf/INFO2 = {“WebServerMode”:“Admin”,“Hostname”:“sonoff_rf-1783”,“IPAddress”:“192.168.1.90”}
00:00:06 MQT: tele/sonoff_rf/INFO3 = {“RestartReason”:“Software/System restart”}
15:59:14 MQT: tele/sonoff_rf/STATE = {“Time”:“2019-06-20T15:59:14”,“Uptime”:“0T00:00:13”,“Vcc”:3.124,“Wifi”:{“AP”:1,“SSId”:“DrayTek”,“RSSI”:80,“APMac”:“00:1D:AA:6D:10:D0”}}
16:00:00 MQT: tele/sonoff_rf/RESULT = {“RfReceived”:{“Sync”:12460,“Low”:410,“High”:1220,“Data”:“D49B1E”,“RfKey”:“None”}}
16:00:28 MQT: tele/sonoff_rf/RESULT = {“RfReceived”:{“Sync”:12540,“Low”:420,“High”:1220,“Data”:“D49B1E”,“RfKey”:“None”}}
16:02:00 MQT: tele/sonoff_rf/UPTIME = {“Time”:“2019-06-20T16:02:00”,“Uptime”:“0T00:02:59”}
16:03:47 MQT: tele/sonoff_rf/RESULT = {“RfReceived”:{“Sync”:13140,“Low”:430,“High”:1250,“Data”:“FA97D1”,“RfKey”:“None”}}
16:03:49 MQT: tele/sonoff_rf/RESULT = {“RfReceived”:{“Sync”:13060,“Low”:420,“High”:1270,“Data”:“FA97D1”,“RfKey”:“None”}}
16:04:16 MQT: tele/sonoff_rf/STATE = {“Time”:“2019-06-20T16:04:16”,“Uptime”:“0T00:05:15”,“Vcc”:3.123,“Wifi”:{“AP”:1,“SSId”:“DrayTek”,“RSSI”:78,“APMac”:“00:1D:AA:6D:10:D0”}}
16:08:35 MQT: tele/sonoff_rf/RESULT = {“RfReceived”:{“Sync”:12660,“Low”:430,“High”:1210,“Data”:“080521”,“RfKey”:“None”}}
16:09:11 APP: Serial logging disabled
16:09:24 MQT: tele/sonoff_rf/STATE = {“Time”:“2019-06-20T16:09:24”,“Uptime”:“0T00:10:23”,“Vcc”:3.122,“Wifi”:{“AP”:1,“SSId”:“DrayTek”,“RSSI”:70,“APMac”:“00:1D:AA:6D:10:D0”}}
Any ideas? It’s driving me NUTS!
