Hi! I’m trying to connect HA with another service (“Multisystem reactor” aka MSR, similiar to Node red). But when MSR tries to connect to HA I only get this:
2021-03-14T15:20:27.492Z HassController:NOTICE HassController#hass attempting reconnection to ws://192.168.50.167:8123/api/websocket 2021-03-14T15:20:27.492Z HassController:NOTICE HassController#hass connecting to ws://192.168.50.167:8123/api/websocket 2021-03-14T15:20:27.501Z HassController:WARN HassController#hass socket error during open: Error: socket hang up 2021-03-14T15:20:27.502Z HassController:NOTICE HassController#hass socket to ws://192.168.50.167:8123/api/websocket closed during open 2021-03-14T15:20:27.505Z HassController:ERR HassController#hass connect error with ws://192.168.50.167:8123/api/websocket: websocket error 2021-03-14T15:20:27.505Z HassController:WARN HassController#hass failed to connect/initialize communication: websocket error
In my configuration.yaml I have the line:
websocket_api:
I have all the latest versions of everything:
Version
core-2021.3.4
Installation Type
Home Assistant OS
Development
false
Supervisor
true
Docker
true
Virtual Environment
false
Python Version
3.8.7
Operating System Family
Linux
Operating System Version
5.4.99
CPU Architecture
x86_64
Timezone
Europe/Stockholm
Host Operating System
Home Assistant OS 5.12
Update Channel
stable
Supervisor Version
supervisor-2021.03.6
Docker Version
19.03.13
Disk Total
30.8 GB
Disk Used
16.8 GB
Healthy
true
Supported
true
Board
ova
Supervisor API
ok
Version API
ok
Why wont it work? What am I missing? Thanks in advance!
Best regards,
/Fanan
HA’s websocket implementation includes an authentication phase as the first connection. So, whatever tool you are using has to be able to support that initial authentication phase:
Server states#
Client connects.
Authentication phase starts.
Server sends auth_required message.
Client sends auth message.
If auth message correct: go to 3.
Server sends auth_invalid. Go to 6.
Send auth_ok message
Authentication phase ends.
Command phase starts.
Client can send commands.
Server can send results of previous commands.
Client or server disconnects session.
Hi @code-in-progress! MSR is used by many more, and they don’t have this problem - so MSR is fully capable. I have followed every guide and every step. I didn’t mention, but I have created a long time access token, which should do the trick. I just can’t get my head around this…
Huh… From the log, it looks like it can’t open the port.
Can you open https://www.websocket.org/echo.html and test your HA websocket connection? Down in location, enter in ws://192.168.50.167:8123/api/websocket and see if you can connect to it.
No, it won’t connect. Another question related to this; do I have to install any integration or add-on to make this work? I have only added the single line to the configuration.yaml file.
I’m using duckdns and Lets encrypt. Maybe thats messing with my websocket?
I feel like a total newbee here…
Hi @code-in-progress! No need for excuses! I’m grateful for all help I can get!
When I test:
nothing happens - it´s like I don’t have pushed the connect button.
The example: wss://echo.websocket.org work just fine. So it´s something wrong with my adress I guess. I have portforwarded 192.168.50.167:8123 in my router, so that shouldn’t be the error. Getting crazy here…
You shouldn’t have to forward anything. The code on that page actually runs locally through javascript.
Ok. Let’s try another approach: On WebSocket API | Home Assistant Developer Docs there are three links near the top. Click on the Python link. It’ll open a new tab with some raw python in it. Copy that to a file on your local system and name it something like haws.py. Change the token in the line starting with ACCESS_TOKEN to use your token and change the line websocket = await asyncws.connect('ws://localhost:8123/api/websocket') to the IP address of your HA server. Then, run the file using python3 haws.py. If all goes well, you’ll see something like this:
Hmmmm… are you certain that the IP is correct? If that python code fails, then there’s no socket listening at that port. What IP do you use to hit HA in your browser? Is it the same?
Hi. When I look in the Supervisor log, this is what I see:
`21-04-06 05:56:47 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-48091' coro=<HomeAssistantWebSocket.async_send_command() done, defined at /usr/src/supervisor/supervisor/homeassistant/websocket.py:101> exception=TypeError('Received message 257:None is not str')>
File "/usr/src/supervisor/supervisor/homeassistant/websocket.py", line 129, in async_send_command
return await self._client.async_send_command(message)
File "/usr/src/supervisor/supervisor/homeassistant/websocket.py", line 46, in async_send_command
response = await self.client.receive_json()
File "/usr/local/lib/python3.8/site-packages/aiohttp/client_ws.py", line 291, in receive_json
data = await self.receive_str(timeout=timeout)
File "/usr/local/lib/python3.8/site-packages/aiohttp/client_ws.py", line 276, in receive_str
raise TypeError(f"Received message {msg.type}:{msg.data!r} is not str")
TypeError: Received message 257:None is not str`
Don’t know if it´s to any help to understand the problem…
I´m so greatful for any help. Thanks!
/Fanan
Fanan, i have almost the same error as yours in the supervisor log, and im not using any MSR service. So i dont think is something non related to that svc.
Hi @code-in-progress! Did you find anything?
My HA installation was on a VM on a PC. I the installed it on a RPi 4 - and that was ok as long as I didn’t restore a snapshot. Then it had the same issues.
From your browser screenshot, it seems you have https enabled. Is it correct?
If so, the protocol is wss://, and, as it seems you use some self-signed certificate, you have to be sure to ignore the certificate errors in whatever client.
