I’m moving over from Homeseer and I can’t get a zwave automation working. I’m obviously missing something. The trigger just will not fire. Here’s the automation:
- id: basement_lights_double_off
alias: Basement Lights - double off
- platform: event
event_type: zwave.scene_activated
event_data:
entity_id: switch.basement_stairs_lights
scene_id: 2
scene_data: 7860
- service: homeassistant.turn_off
entity_id: group.basement_lights
Here’s what I’ve done to set this up:
Modified zwcfg_0x*.xml to update the COMMAND_CLASS_CENTRAL_SCENE for my Homeseer switches. https://www.home-assistant.io/docs/z-wave/device-specific/#homeseer-switches
Check the zwave log to see if the scene data in happening, it is.
2019-03-24 11:29:11.978 Detail, Node006, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x06, 0x05, 0x5b, 0x03, 0x7b, 0x83, 0x02, 0x51
2019-03-24 11:29:11.979 Detail,
2019-03-24 11:29:11.979 Info, Node006, Received Central Scene set from node 6: scene id=2 in 7860 seconds. Sending event notification.
2019-03-24 11:29:11.979 Detail, Node006, Refreshed Value: old value=7860, new value=7860, type=int
2019-03-24 11:29:11.979 Detail, Node006, Changes to this value are not verified
2019-03-24 11:29:11.980 Detail, Node006, Notification: ValueChanged -
Go to “States” in the UI and make sure the automation is on. I also can force the trigger and the action does happen.
Go back into zwcfg_0x*.xml and double check the firmware version of the switch and see the last value of the scene data. All looks good.
The “has been triggered” Automation never shows up in the Logbook.
Everything else zwave wise works fine. What I’m I missing?
Thanks…Steely
