I feel like this could be a bug, but I’m currently trying to setup the ring-mqtt streaming using the generic camera integration (as instructed in the documentation: ring-mqtt/docs/CAMERAS.md at 3943159123e685547a673a751faf927f53bbf210 · tsightler/ring-mqtt · GitHub).
If I setup the generic camera in the configuration file (or in the UI) without the still image URL, it actually works fine, but without the still image capability. However, I really want to have the still image capability so it’s not launching a stream every time I launch the picture glance card on the dashboard.
So, when I attempt to enter in the url, as instructed, into the still image configuration, I get an error.
Here’s an example of what I’m adding to the configuration.yml (secrets replaced with non-identifying values):
camera:
- platform: generic
still_image_url: http://192.168.10.242:8123{{ states.camera.ring_doorbell_snapshot.attributes.entity_picture }}
stream_source: rtsp://username:[email protected]:8554/12345678910_live
verify_ssl: false
This fails due to an ‘Unknown Error’. And when I check the log file, I see that there was an interesting problem with the processing of the still_image URL as follows:
ValueError: Port could not be cast to integer value as '8123{{ states.camera.ring_doorbell_snapshot.attributes.entity_picture }}'
For some reason, it’s not separating the port number from the template provided.
And from the documentation, it specifies NOT to put a slash after the port:
Note that the still_image_url uses the guessed hostname and/or localhost. This could work in some cases, but if SSL is enabled or the default default port has been changed, the correct URL may not be reflected here, simple use the Home Assistant base URL with the value template on the end and make sure there is no slash after the hostname or port. For example, if the Home Assistant instance is accessed directly via https://myha.mydomain.local/ then the URL would be https://myha.mydomain.local{{ states.camera.front_porch_snapshot.attributes.entity_picture }}.
Thanks in advance for any help or guidance!
