Hi all, I’m at a complete loss at this point and hoping the kind dwellers of these forums can shine a light on my stupidity.
My instance of HA seems to have had quite the bad time after I was adding a few bits and bobs and I have no clue how to recover.
Currently the logs are showing errors such as:
Logger: homeassistant
Source: core.py:1186
First occurred: 10:23:19 (2 occurrences)
Last logged: 10:23:49
Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 182, in _handle_refresh_interval
await self._async_refresh(log_failures=True, scheduled=True)
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 330, in _async_refresh
self.async_update_listeners()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 135, in async_update_listeners
update_callback()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 559, in async_write_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 676, in _async_write_ha_state
self.hass.states.async_set(
File "/usr/src/homeassistant/homeassistant/core.py", line 1537, in async_set
state = State(
File "/usr/src/homeassistant/homeassistant/core.py", line 1186, in __init__
raise InvalidStateError(
homeassistant.exceptions.InvalidStateError: Invalid state encountered for entity ID: sensor.kfsuwi_current_page. State max length is 255 characters.
and
Logger: zigpy.zcl
Source: runner.py:179
First occurred: 10:23:02 (1 occurrences)
Last logged: 10:23:02
[0x1EAB:1:0x0b04] Traceback (most recent call last): File "/usr/local/lib/python3.10/site-packages/zigpy/zcl/__init__.py", line 358, in reply return await self._endpoint.reply( File "/usr/local/lib/python3.10/site-packages/zigpy/endpoint.py", line 256, in reply return await self.device.reply( File "/usr/local/lib/python3.10/site-packages/zigpy/device.py", line 384, in reply return await self.request( File "/usr/local/lib/python3.10/site-packages/zigpy/device.py", line 297, in request await self._application.request( File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 692, in request await self.send_packet( File "/usr/local/lib/python3.10/site-packages/zigpy_deconz/zigbee/application.py", line 402, in send_packet await self._api.aps_data_request( AttributeError: 'NoneType' object has no attribute 'aps_data_request'
and a few others… I’m not sure which are relevant and which could be the root cause…
Looking at things via Samba it seemed the sqlite database was corrupted so I spent some time scouring the forums and tried the .recover trick but to no avail.
Anyone willing to help me work out where to go from here? I am completely lost
