Hey everyone,
I’m relatively new to the scene and don’t have much experience with electronics and programming, but I’m currently working on a project that involves an ESP32 microcontroller, a specific pinout configuration, and a power meter. However, I’ve encountered an issue and could really use some guidance. Here’s what I have:
ESP32 with the following pinout: ESP32_DevKit_C_V4_Pinout.pdf (shopify.com)
A power meter with the instructions available here: Eastron SDM220M* User Manual (xn–stromzhler-v5a.eu) an TTL to RS485 module:
I have wired everything according to this diagram (of course the ESP and the power meter are connected to power supply):
In my ESPHome configuration, I have the following code for this setup:
esphome:
friendly_name: Rs485
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
baud_rate: 0
uart:
tx_pin: GPIO1
rx_pin: GPIO3
baud_rate: 9600
stop_bits: 2
modbus:
flow_control_pin: GPIO0
modbus_controller:
- id: controller
## the Modbus device addr
address: 0x1
modbus_id: modbus1
- platform: modbus_controller
modbus_controller_id: controller
address: 30049
register_type: holding
value_type: U_DWORD
unit_of_measurement: "A"
# Enable Home Assistant API
api:
encryption:
key: "P/LTB5girwA0bT84O0lL7bLzGszImPRhWTBNQaSTeIs="
ota:
password: "410734d9197a1988aea69177ccb0269c"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Rs485 Fallback Hotspot"
password: "lRKwYkASr0kA"
captive_portal:
However, when I check the logs, I see the following error message:
[D][modbus_controller:032]: Modbus command to device=1 register=0x1683 countdown=0 no response received - removed from send queue
Additionally, the entity associated with the power meter shows a status of “Unknown.”
I’m trying to figure out what I might be doing wrong here. Any tips or suggestions would be greatly appreciated. Thank you in advance!
Best regards, Felix
