Hi All,
I’m troubleshooting a Gosund SP112 (EU) Power-Monitoring Plug flashed with Esphome.
Looking For Help On
How do I troubleshoot a plug that seems to randomly reboot after 30 mins or so.
I know because default behavior was to turn-on light on reboot. Light kept coming on.
Behavior seems to lose connection to server, and then reboot plug
I am looking for guidance on how to troubleshooting plug
Version Info
Home Assistant 2021.9.6
Version core-2021.9.6
client_info: ‘Home Assistant 2021.9.6’
esphome v2021.8.2
I have log file from esphome, but didn’t want to post for brevity.
Thank you in advance for any tips!
~Bryan
# From HomeAssistant Logbook
# Devices is called Relay Mains, and reboots radomly after 30 or 15 mins.
Relay Mains turned off 6:10:58 PM - 48 seconds ago
Relay Mains became unavailable 6:10:54 PM - 52 seconds ago
Relay Mains turned off 5:17:16 PM - 54 minutes ago
Relay Mains became unavailable 5:15:47 PM - 56 minutes ago
Relay Mains turned off 5:01:40 PM - 1 hour ago
Relay Mains became unavailable 5:01:06 PM - 1 hour ago
Relay Mains turned off 4:31:26 PM - 2 hours ago
Relay Mains became unavailable 4:31:24 PM - 2 hours ago
Relay Mains turned off 4:27:55 PM - 2 hours ago
Relay Mains became unavailable 4:27:45 PM - 2 hours ago
Esphome Config
substitutions:
system_name: mbr_lamp
friendly_name: MBR Lamp Plug
device_description: "Used for lamp, and power management for Bryan's Side of Bed."
restore_mode: ALWAYS_ON
esphome:
platform: ESP8266
arduino_version: 2.5.1
board: esp01_1m
on_boot:
priority: -10
then:
- switch.turn_off: switch1
<<: !include .common/common.yaml
# Enable logging
logger:
level: VERY_VERBOSE #DEBUG is the default
switch:
- platform: gpio
pin: GPIO14
- platform: gpio
restore_mode: ${restore_mode}
pin:
number: GPIO13
inverted: true
binary_sensor:
name: "${friendly_name} Button 1"
# read analog sensor and convert it's value to binary state
lambda: return (id(button_adc).state < .5);
on_click:
# short button press toggles mains
- min_length: 10ms
max_length: 250ms
then:
- switch.toggle: switch1
# long button press toggles USB
- min_length: 250ms
max_length: 1000ms
then:
- switch.toggle: switchusb
- platform: adc
pin: A0
update_interval: 30s
- platform: hlw8012
sel_pin:
number: GPIO12
inverted: True
cf_pin: GPIO05
cf1_pin: GPIO04
current_resistor: 0.00221
voltage_divider: 871
change_mode_every: 8
update_interval: 60s
current:
name: "${friendly_name} Amperage"
voltage:
power:
