I have a few questions, one how do i fix this error:
Logger: homeassistant.config_entries
Source: components/hassio/handler.py:540
First occurred: 12:42:40 (1 occurrences)
Last logged: 12:42:40
Error setting up entry Supervisor for hassio
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 387, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 665, in async_setup_entry
await coordinator.async_config_entry_first_refresh()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 257, in async_config_entry_first_refresh
await self._async_refresh(
File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 974, in _async_refresh
await self.hassio.refresh_updates()
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 37, in _wrapper
data = await funct(*argv, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 540, in send_command
request = await self.websession.request(
File "/usr/local/lib/python3.11/site-packages/aiohttp/client.py", line 560, in _request
await resp.start(conn)
File "/usr/local/lib/python3.11/site-packages/aiohttp/client_reqrep.py", line 899, in start
message, payload = await protocol.read() # type: ignore[union-attr]
File "/usr/local/lib/python3.11/site-packages/aiohttp/streams.py", line 616, in read
await self._waiter
asyncio.exceptions.CancelledError: Global task timeout
And number two, how to solve?
I can briefly see my Lovelace frontend, and then pops up Message “Service system_log/write called”, and then blank
What is this happening, how to solve?
Logger: py.warnings
Source: components/camera/img_util.py:50
First occurred: 16:36:54 (1 occurrences)
Last logged: 16:36:54
/usr/local/lib/python3.11/site-packages/turbojpeg.py:901: UserWarning: Corrupt JPEG data: 608 extraneous bytes before marker 0xfe warnings.warn(self.__get_error_string(handle))
What to do with this one?
Logger: homeassistant.components.zha.core.cluster_handlers
Source: components/zha/core/cluster_handlers/__init__.py:537
Integration: Zigbee Home Automation (documentation, issues)
First occurred: 16:34:01 (3 occurrences)
Last logged: 16:34:01
[0xAF7A:1:0x0006]: async_initialize: all attempts have failed: [DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>')]
[0xAF7A:1:0x0b04]: async_initialize: all attempts have failed: [DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>')]
[0xAF7A:1:0x0702]: async_initialize: all attempts have failed: [DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>')]
