My HA semi broke this morning after running +100 days with no interruption. I have tried everything I can think of, but I am too novice to troubleshoot further.
I did not touch the system before the issue happened. I am running HA OS on a mini pc with proxmox. I was not able to reach my webinterface and i logged on to Proxmox and saw my CPU pinned to 100% on my HA vm. I as unable to restart HA from Proxmox because of “TASK ERROR: can’t lock file ‘/var/lock/qemu-server/lock-100.conf’ - got timeout” – i ended up just forcing the node to restart.
After HA booted up there was many issues, mainly a many of my integrations failing to load properly. To me it seems like some underlying issue causing many of the integrations to fail to load. Network issue?, DNS? I have so many errors in my logs that I do not know where to start – does anyone have an idea? I have attached some logs and screenshots, if more are needed, please let me know. Any help is much appreciated.
I am also not able to access HA externally with the error: Error code:
Secure connection failed.
PR_END_OF_FILE_ERROR
And the app shows:
Failed to perfom SSL handshake.
Troubleshooting tried so far:
Rebooting HA
Recovering from backup
Removing unneeded integrations
Updating to latest version
DNS logs:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/corefile.sh
cont-init: info: /etc/cont-init.d/corefile.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun coredns (no readiness notification)
s6-supervise coredns: warning: unable to spawn ./run (waiting 60 seconds): Exec format error
Core logs:
2024-03-21 10:53:39.260 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-03-21 10:53:39.262 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration astroweather which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-03-21 10:53:39.263 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration alarmo which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-03-21 10:53:39.264 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-03-21 10:53:39.264 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration nordpool which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-03-21 10:53:39.265 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration adaptive_lighting which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-03-21 10:53:39.266 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration watchman which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-03-21 10:53:45.549 WARNING (MainThread) [homeassistant.config_entries] Config entry ' for tuya integration could not authenticate: Authentication failed. Please re-authenticate.
2024-03-21 10:53:46.025 WARNING (MainThread) [homeassistant.components.alarm_control_panel] FORMAT_NUMBER was used from alarmo, this is a deprecated constant which will be removed in HA Core 2025.1. Use CodeFormat.NUMBER instead, please create a bug report at https://github.com/nielsfaber/alarmo/issues
2024-03-21 10:53:46.029 WARNING (MainThread) [homeassistant.components.alarm_control_panel] FORMAT_NUMBER was used from alarmo, this is a deprecated constant which will be removed in HA Core 2025.1. Use CodeFormat.NUMBER instead, please create a bug report at https://github.com/nielsfaber/alarmo/issues
2024-03-21 10:53:47.890 ERROR (MainThread) [homeassistant.util.logging] Exception in async_alarm_state_changed when dispatching 'alarmo_state_updated': ('1700421419', None, 'armed_home')
File "/config/custom_components/alarmo/mqtt.py", line 61, in async_alarm_state_changed
if not self._config[ATTR_MQTT][const.ATTR_ENABLED] or not new_state:
TypeError: 'NoneType' object is not subscriptable
2024-03-21 10:53:50.557 ERROR (SyncWorker_1) [homeassistant.components.nut] Failure getting NUT ups alias, Socket error.
2024-03-21 10:53:50.694 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry for roborock
File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 1173, in _create_direct_connection
hosts = await asyncio.shield(host_resolved)
File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 884, in _resolve_host
addrs = await self._resolver.resolve(host, port, family=self._family)
File "/usr/local/lib/python3.12/site-packages/aiohttp/resolver.py", line 33, in resolve
infos = await self._loop.getaddrinfo(
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 899, in getaddrinfo
return await self.run_in_executor(
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.12/socket.py", line 963, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 504, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/roborock/__init__.py", line 36, in async_setup_entry
home_data = await api_client.get_home_data(user_data)
File "/usr/local/lib/python3.12/site-packages/roborock/web_api.py", line 201, in get_home_data
home_id = await self._get_home_id(user_data)
File "/usr/local/lib/python3.12/site-packages/roborock/web_api.py", line 181, in _get_home_id
home_id_response = await home_id_request.request(
File "/usr/local/lib/python3.12/site-packages/roborock/web_api.py", line 297, in request
async with session.request(
File "/usr/local/lib/python3.12/site-packages/aiohttp/client.py", line 1194, in __aenter__
self._resp = await self._coro
File "/usr/local/lib/python3.12/site-packages/aiohttp/client.py", line 578, in _request
conn = await self._connector.connect(
File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 544, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 911, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 1187, in _create_direct_connection
raise ClientConnectorError(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host euiot.roborock.com:443 ssl:default [Try again]
2024-03-21 10:53:50.712 ERROR (MainThread) [metno] Access to https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned error 'ClientConnectorError'
2024-03-21 10:53:51.535 WARNING (SyncWorker_2) [homeconnect] Token expired.
2024-03-21 10:53:53.202 ERROR (Thread-4) [pychromecast.socket_client] [SHIELD(96b49e67-320a-0408-c61b-01585aa69646.local.):8009] Failed to connect to service MDNSServiceInfo(name='SHIELD-Android-TV-96b49e67320a0408c61b01585aa69646._googlecast._tcp.local.'), retrying in 5.0s
2024-03-21 10:53:53.550 ERROR (MainThread) [custom_components.hacs] Request exception for 'https://api.github.com/rate_limit' with - Cannot connect to host api.github.com:443 ssl:default [Try again]
File "/config/custom_components/hacs/base.py", line 464, in async_can_update
response = await self.async_github_api_method(self.githubapi.rate_limit)
File "/config/custom_components/hacs/base.py", line 522, in async_github_api_method
raise HacsException(_exception)
custom_components.hacs.exceptions.HacsException: Request exception for 'https://api.github.com/rate_limit' with - Cannot connect to host api.github.com:443 ssl:default [Try again]
2024-03-21 10:53:53.557 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'hacs' accesses hass.components.frontend. This is deprecated and will stop working in Home Assistant 2024.9, it should be updated to import functions used from frontend directly at custom_components/hacs/frontend.py, line 58: hass.components.frontend.async_register_built_in_panel(, please create a bug report at https://github.com/hacs/integration/issues
2024-03-21 10:53:56.543 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Home Assistant for home_connect
File "/usr/src/homeassistant/homeassistant/components/home_connect/__init__.py", line 229, in async_setup_entry
await update_all_devices(hass, entry)
File "/usr/src/homeassistant/homeassistant/components/home_connect/__init__.py", line 253, in update_all_devices
await hass.async_add_executor_job(hc_api.get_devices)
File "/usr/src/homeassistant/homeassistant/components/home_connect/api.py", line 70, in get_devices
appl = self.get_appliances()
File "/usr/local/lib/python3.12/site-packages/homeconnect/api.py", line 136, in get_appliances
data = self.get(ENDPOINT_APPLIANCES)
File "/usr/local/lib/python3.12/site-packages/homeconnect/api.py", line 83, in get
res = self.request("get", endpoint)
File "/usr/local/lib/python3.12/site-packages/homeconnect/api.py", line 77, in request
self._oauth.token = self.refresh_tokens()
File "/usr/src/homeassistant/homeassistant/components/home_connect/api.py", line 64, in refresh_tokens
).result()
File "/usr/local/lib/python3.12/concurrent/futures/_base.py", line 456, in result
return self.__get_result()
File "/usr/local/lib/python3.12/concurrent/futures/_base.py", line 401, in __get_result
raise self._exception
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 519, in async_ensure_token_valid
new_token = await self.implementation.async_refresh_token(self.token)
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 94, in async_refresh_token
new_token = await self._async_refresh_token(token)
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 184, in _async_refresh_token
new_token = await self._token_request(
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 203, in _token_request
resp = await session.post(self.token_url, data=data)
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host api.home-connect.com:443 ssl:default [Try again]
2024-03-21 10:53:57.305 WARNING (MainThread) [zigpy.application] Zigbee channel 23 utilization is 88.70%!
2024-03-21 10:53:57.305 WARNING (MainThread) [zigpy.application] If you are having problems joining new devices, are missing sensor updates, or have issues keeping devices joined, ensure your coordinator is away from interference sources such as USB 3.0 devices, SSDs, WiFi routers, etc.
2024-03-21 10:54:45.426 WARNING (MainThread) [hass_nabucasa.iot] Cannot connect because unable to refresh token:
2024-03-21 10:54:47.453 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud (timeout)
2024-03-21 10:55:01.402 ERROR (SyncWorker_5) [homeassistant.util.package] Unable to install package pyastroweatherio==0.42.5: WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f1815808080>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pyastroweatherio/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f18157e3ad0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pyastroweatherio/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f1814a54620>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pyastroweatherio/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f1814a54650>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pyastroweatherio/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f1814a54830>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pyastroweatherio/
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f1814a54a10>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux-index/pyastroweatherio/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f1814a54e00>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux-index/pyastroweatherio/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f1814a55010>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux-index/pyastroweatherio/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f1814a55220>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux-index/pyastroweatherio/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f1814a55490>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux-index/pyastroweatherio/
ERROR: Could not find a version that satisfies the requirement pyastroweatherio==0.42.5 (from versions: none)
ERROR: No matching distribution found for pyastroweatherio==0.42.5
2024-03-21 10:55:23.652 WARNING (MainThread) [hass_nabucasa.iot] Cannot connect because unable to refresh token:
2024-03-21 10:55:27.456 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud (timeout)
2024-03-21 10:56:01.526 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [139914181853632] Error updating Z-Wave JS: 'BackupManager.do_backup_partial' blocked from execution, system is not running - startup
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 167, in async_install
await async_update_addon(self.hass, slug=self._addon_slug, backup=backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 58, in _wrapper
data = await funct(*argv, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 135, in async_update_addon
return await hassio.send_command(
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 592, in send_command
raise HassioAPIError(error.get(ATTR_MESSAGE))
homeassistant.components.hassio.handler.HassioAPIError: 'BackupManager.do_backup_partial' blocked from execution, system is not running - startup
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 239, in handle_call_service
response = await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 2319, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2356, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 905, in entity_service_call
single_response = await _handle_entity_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 975, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 161, in async_install
await entity.async_install_with_progress(version, backup)
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 465, in async_install_with_progress
await self.async_install(version, backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 169, in async_install
raise HomeAssistantError(f"Error updating {self.title}: {err}") from err
homeassistant.exceptions.HomeAssistantError: Error updating Z-Wave JS: 'BackupManager.do_backup_partial' blocked from execution, system is not running - startup
2024-03-21 10:56:06.572 WARNING (MainThread) [hass_nabucasa.iot] Cannot connect because unable to refresh token:
2024-03-21 10:56:07.460 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud (timeout)
2024-03-21 10:56:18.521 ERROR (SyncWorker_5) [homeassistant.util.package] Unable to install package pyastroweatherio==0.42.5: WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fce8b8683b0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pyastroweatherio/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fce8944ec90>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pyastroweatherio/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fce8932c680>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pyastroweatherio/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fce8932c350>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pyastroweatherio/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fce8932c890>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pyastroweatherio/
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fce8932cbc0>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux-index/pyastroweatherio/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fce8932cec0>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux-index/pyastroweatherio/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fce8932d0d0>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux-index/pyastroweatherio/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fce8932d2e0>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux-index/pyastroweatherio/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fce8932d550>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux-index/pyastroweatherio/
2024-03-21 10:56:21.495 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /store/addons/core_zwave_js/update - 'BackupManager.do_backup_partial' blocked from execution, system is not running - startup
2024-03-21 10:56:47.462 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud (timeout)
2024-03-21 10:56:51.498 WARNING (MainThread) [hass_nabucasa.iot] Cannot connect because unable to refresh token:
2024-03-21 10:57:27.465 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud (timeout)
2024-03-21 10:57:35.652 ERROR (SyncWorker_5) [homeassistant.util.package] Unable to install package pyastroweatherio==0.42.5: WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f507044c8c0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pyastroweatherio/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f506f594290>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pyastroweatherio/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f506f594830>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pyastroweatherio/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f506f594950>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pyastroweatherio/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f506f594bf0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pyastroweatherio/
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f506f594ef0>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux-index/pyastroweatherio/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f506f5951c0>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux-index/pyastroweatherio/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f506f595340>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux-index/pyastroweatherio/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f506f5955b0>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux-index/pyastroweatherio/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f506f595820>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux-index/pyastroweatherio/
2024-03-21 10:57:35.653 ERROR (MainThread) [homeassistant.setup] Setup failed for custom integration 'astroweather': Requirements for astroweather not found: ['pyastroweatherio==0.42.5'].
