eemceebee
(Sebastian)
April 7, 2022, 3:21pm
1
Hi, I need to get i2c to be enabled and I followed the instructions from Common Tasks - Operating System - Home Assistant using the Terminal.
But I can not get this to work this way. I need to use the Terminal as I use an SSD drive and can not access this directly due to lack of an adapter
Anyway, according to the docu it should work also directly in the Terminal, but after the reboot I do not have a /dev/i2c-0 or anything similar.
I do see a device when I run lsmod | grep “i2c → i2c 20480 0”, so it is there, but if it does not show up in /dev, I assume it is still not enabled?
Any help ?
eemceebee
(Sebastian)
April 7, 2022, 9:24pm
2
So, someone created a nice Addon which is doing the exact thing needed and it works. Not sure what the addon is doing differently, cause in the logs it shows exactly what i did directly in the terminal, but well, it works.
HassOS I2C Configurator
[image]
This project enables the Raspberry Pi I2C bus from an addon. You can connect an SDCard and up to two hard disks or USB drives, which are detected as sda or sdb, and they will all have I2C enabled when you click start.
About
This project is a part of my HassOS Configurator project. The goal of this add-on, similar to root apps on Android, is to make a mole-hill out of a mountain.
Installation
Within Home Assistant, click Supervisor-> Add-on Store → … button (…
