I am attempting to turn on a GROUP of lights when a sensor is triggered. At the moment I am only successful when turning on 1 light. Partly because I use “device type” instead of " Condition" for my action type selection.
I have groups created using visual studio HA add-on
entities:
- light.lr_color_1
- light.lr_color_2
- light.lr_color_3
- light.lr_color_4
- light.lr_color_5
all: "true"
type or paste code here
However I am not really interested in using HAGroup, I have also created HueGroupLivingRoomLights, that was created as a ‘room’ in the Hue app. Either way I have been unsuccessful with either group. I have a feeling I am using the ‘Actions’ section incorrectly.
I navigated to my automations folder and have copied the yaml part associated with this automation for easier troubleshooting below.
alias: NightDoorOpenON
description: This will trigger when front door is open at night, outside lights
and living room lights should turn on.
- type: opened
platform: device
device_id: aa66461a01a246c5905553eaf02128b1
entity_id: binary_sensor.lumi_lumi_sensor_magnet_aq2_77c83a03_on_off
domain: binary_sensor
condition: []
- condition: state
entity_id: light.huegroup_livingroom
state: 'on'
mode: single
This will appear as a single light that you can set brightness, colour etc… also you can use the light.turn_on/off services instead of the homeassistant.turn_on/off services.
EDIT: oh it’s a hue group. I’d still use the light group platform.Ignore all this.
I disagree, the groups created from Hue are better for this.
When you have e.g. 10 lights in chandelier and turn it on from HA, with the light group HA will send 10 commands to the Hue bridge, which can lead to delayed/missing commands. Whereas with a group created in Hue, HA sends only one command to the Hue bridge and it will then automatically propagate the command to the individual bulbs accordingly.
Burningstone, thanks for your clear and easy recommendation. This indeed did solve my problem.
Tom, I actually still appreciate this information, even though I have a HueGroupLightXX, I also clone them with a native HA group. I plan to redo all of my HAGroupLightsXX following the light group platform.
Apmillen
I also appreciate your suggestion, it is one I have tried and does work in other situations, just not the living room.
Oh wanted to respond before going to bed. I am definitely using Hue native groups over HA groups.
I will still create HA groups just in case I ever run into an odd scenario. Also I have lights that arent hue branded.
For anyone else reading this, as Burningstone mention using Hue groups will send 1 request to the hub and the hub will figure it out.
