Which Z2M version did you use? My TZE284 didn’t show any sensor data. It connected successfully but i wasn’t able to get data.
Other question @ShadowFist i have a problem configuring the custom quirk for my tze284. It doesn’t seem to be picked up. (see Screenshot and code). Any idea what could be the problem?
Any hints are highly appreciated. Thank you!
Generally the quirks are loaded:
Logger: zhaquirks
Quelle: /usr/local/lib/python3.12/site-packages/zhaquirks/__init__.py:469
Erstmals aufgetreten: 15:12:49 (1 Vorkommnisse)
Zuletzt protokolliert: 15:12:49
Loaded custom quirks. Please contribute them to https://github.com/zigpy/zha-device-handlers
"""Tuya temp and humidity sensors."""
from typing import Any, Dict
from zigpy.profiles import zha
from zigpy.quirks import CustomDevice
from zigpy.zcl.clusters.general import Basic, Groups, Ota, Scenes, Time
from zigpy.zcl.clusters.measurement import (
RelativeHumidity,
SoilMoisture,
TemperatureMeasurement,
from zhaquirks.const import (
DEVICE_TYPE,
ENDPOINTS,
INPUT_CLUSTERS,
MODELS_INFO,
OUTPUT_CLUSTERS,
PROFILE_ID,
SKIP_CONFIGURATION,
from zhaquirks.tuya import TuyaLocalCluster, TuyaPowerConfigurationCluster2AAA
from zhaquirks.tuya.mcu import DPToAttributeMapping, TuyaMCUCluster
class TuyaTemperatureMeasurement(TemperatureMeasurement, TuyaLocalCluster):
"""Tuya local TemperatureMeasurement cluster."""
class TuyaSoilMoisture(SoilMoisture, TuyaLocalCluster):
"""Tuya local SoilMoisture cluster with a device RH_MULTIPLIER factor if required."""
class TuyaRelativeHumidity(RelativeHumidity, TuyaLocalCluster):
"""Tuya local RelativeHumidity cluster with a device RH_MULTIPLIER factor."""
def update_attribute(self, attr_name: str, value: Any) -> None:
"""Apply a correction factor to value."""
if attr_name == "measured_value":
value = value * (
self.endpoint.device.RH_MULTIPLIER
if hasattr(self.endpoint.device, "RH_MULTIPLIER")
else 100
return super().update_attribute(attr_name, value)
class TemperatureHumidityManufCluster(TuyaMCUCluster):
"""Tuya Manufacturer Cluster with Temperature and Humidity data points."""
dp_to_attribute: Dict[int, DPToAttributeMapping] = {
1: DPToAttributeMapping(
TuyaTemperatureMeasurement.ep_attribute,
"measured_value",
converter=lambda x: x * 10, # decidegree to centidegree
2: DPToAttributeMapping(
TuyaRelativeHumidity.ep_attribute,
"measured_value",
# converter=lambda x: x * 10, --> move conversion to TuyaRelativeHumidity cluster
4: DPToAttributeMapping(
TuyaPowerConfigurationCluster2AAA.ep_attribute,
"battery_percentage_remaining",
converter=lambda x: x * 2, # double reported percentage
data_point_handlers = {
1: "_dp_2_attr_update",
2: "_dp_2_attr_update",
4: "_dp_2_attr_update",
class TuyaTempHumiditySensor(CustomDevice):
"""Custom device representing tuya temp and humidity sensor with e-ink screen."""
# RelativeHumidity multiplier
RH_MULTIPLIER = 10
signature = {
# <SimpleDescriptor endpoint=1, profile=260, device_type=81
# device_version=1
# input_clusters=[4, 5, 61184, 0]
# output_clusters=[25, 10]>
MODELS_INFO: [
("_TZE200_bjawzodf", "TS0601"),
("_TZE200_zl1kmjqx", "TS0601"),
ENDPOINTS: {
1: {
PROFILE_ID: zha.PROFILE_ID,
DEVICE_TYPE: zha.DeviceType.SMART_PLUG,
INPUT_CLUSTERS: [
Basic.cluster_id,
Groups.cluster_id,
Scenes.cluster_id,
TemperatureHumidityManufCluster.cluster_id,
OUTPUT_CLUSTERS: [Ota.cluster_id, Time.cluster_id],
replacement = {
SKIP_CONFIGURATION: True,
ENDPOINTS: {
1: {
DEVICE_TYPE: zha.DeviceType.TEMPERATURE_SENSOR,
INPUT_CLUSTERS: [
TemperatureHumidityManufCluster, # Single bus for temp, humidity, and battery
TuyaTemperatureMeasurement,
TuyaRelativeHumidity,
TuyaPowerConfigurationCluster2AAA,
class TuyaTempHumiditySensor_Square(CustomDevice):
# RH_MULTIPLIER = 100
signature = {
MODELS_INFO: [
("_TZE200_a8sdabtg", "TS0601"), # Variant without screen, round
("_TZE200_qoy0ekbd", "TS0601"),
("_TZE200_znbl8dj5", "TS0601"),
ENDPOINTS: {
1: {
# "profile_id": 260, "device_type": "0x0302",
# "in_clusters": ["0x0000","0x0001","0x0402","0x0405"],
# "out_clusters": ["0x000a","0x0019"]
INPUT_CLUSTERS: [
Basic.cluster_id,
TuyaPowerConfigurationCluster2AAA.cluster_id,
TemperatureMeasurement.cluster_id,
RelativeHumidity.cluster_id,
replacement = {
ENDPOINTS: {
1: {
INPUT_CLUSTERS: [
Basic.cluster_id,
class TuyaTempHumiditySensorVar03(CustomDevice):
"""Tuya temp and humidity sensor (variation 03)."""
signature = {
# "device_type": "0x0051",
# "in_clusters": ["0x0000","0x0004","0x0005","0xef00"],
MODELS_INFO: [
("_TZE200_yjjdcqsq", "TS0601"),
("_TZE200_9yapgbuv", "TS0601"),
("_TZE200_qyflbnbj", "TS0601"),
("_TZE200_utkemkbs", "TS0601"),
("_TZE284_myd45weu", "TS0601"),
ENDPOINTS: {
1: {
INPUT_CLUSTERS: [
Basic.cluster_id,
Groups.cluster_id,
Scenes.cluster_id,
replacement = {
ENDPOINTS: {
1: {
INPUT_CLUSTERS: [
Basic.cluster_id,
Groups.cluster_id,
Scenes.cluster_id,
class SoilManufCluster(TuyaMCUCluster):
5: DPToAttributeMapping(
"measured_value",
converter=lambda x: x * 100,
3: DPToAttributeMapping(
TuyaSoilMoisture.ep_attribute,
"measured_value",
15: DPToAttributeMapping(
3: "_dp_2_attr_update",
5: "_dp_2_attr_update",
15: "_dp_2_attr_update",
class TuyaSoilSensor(CustomDevice):
signature = {
MODELS_INFO: [("_TZE284_myd45weu", "TS0601")],
ENDPOINTS: {
1: {
INPUT_CLUSTERS: [
Basic.cluster_id,
Groups.cluster_id,
Scenes.cluster_id,
replacement = {
ENDPOINTS: {
1: {
INPUT_CLUSTERS: [
Basic.cluster_id,
Groups.cluster_id,
Scenes.cluster_id,
SoilManufCluster,
TuyaSoilMoisture,
One strange finding i just made is that another sensor (aqara magnetic door sensor) has a custom quirk mentioned in details although i didn’t manually add it and it’s not in my custom quirk folder.
