I am new to Z-Wave devices. I am running Hass.io Version 0.53.1 on a Raspberry Pi 3. My Z-Wave Controller is the Aeotec Gen 5 Z-Stick.
I purchased two window/door sensors. One is made by Ecolink, one Monoprice. The Ecolink seems to be working well. After pairing, it is showing the Binary Sensor, as well as some ancillary data I haven’t figured out yet on my HA default view. I am able to right automations against it, and I have no real issues.
The Monoprice Sensor paired successfully, and is clearly being recognized by the controller. It shows up in the Z-Wave Configuration screen, but I can’t really configure anything on it. It does not show up in Home Assistant as a recognizable Entity. I can’t figure out what to do to get HA to recognize this device.
Additionally, I tried triggering both devices, about 30 seconds apart, and output the logs. I have included them here. Can someone guide me on the best ways to troubleshoot these devices? Thanks!
Oh yes, there’s a control panel in the Configuration menu. If you use the button then (as it warns in the documentation) you can end up with a broken inclusion, as you’re experiencing.
Ok, so presumably I would have to exclude my devices before reincluding them through the Hass.io interface. Should I exclude them through the interface, or with the button?
Thanks… earlier you stated “as it warns in the documentation.” To what documentation are you referring. Perhaps my problem is that I am not seeing the same resources as everyone else.
Thanks, Tinkerer. I just found another thread here where you helped out someone configuring the same sensor I have, and that was helpful to me too… you’re a rockstar!
