Truncate (shorten) entity names (for dashboard display purposes)?
In my case here, I’m using cards: custom:auto-entities + custom:mushroom-chips-card , however this is a general question as im hoping it can apply to any card type.
Im trying to shorten the names for lights for the dashboard, as using the Lutron Casetta integration, the entities get added as: , example: “Exterior Pool House Lights” (too long in many dashboard cases)
is there a way to apply regex (regex capture-groups im thinking), or another way to shorten these names as they are displayed on the dashboard?
(or worst case is there a way i can hard-code these entity/lights names somewhere and reference those hard-coded names perhaps?)
below is the related dashboard code , and an image showing what im referring to.
(even if one can point me in the right direction, i can figure out how to implement, and will update this post w solution)
thank you!
    cards:
      - type: horizontal-stack
        cards:
          - type: custom:auto-entities
            show_empty: false
            card_param: chips
            card:
              type: custom:mushroom-chips-card
              alignment: left
              tap-action:
                action: more-info
            filter:
              include:
                - domain: light
                  options:
                    type: light
                    content_info: name
                    tap-action:
                      action: more-info
              exclude:
                - name: /[Ss]creen/
                - state: 'off'
                - state: unavailable
                - hidden_by: user
            sort:
              method: friendly_name
        view_layout:
          grid-area: header
<snip>
dash image:
Hopefully there’s a better way, but I think you could do your last choice and hard code a jinja macro.
You can use a similar method as me, using filter template and replace with regex… in my case they have in common in the names Contact Sensor, then the rooms name
thank you for BOTH replies! i marked as solution.
for those curious, this is what i finally went with (with help from chatGPT and alot of fourms searching - ie to get syntax right as This is my first time using jinja2)
                {% for entity in states.light if '_screen' not in entity.entity_id and entity.state == 'on' %}
                  {%- set name = state_attr(entity.entity_id, "friendly_name") -%}
                  {%- set name = name | regex_replace(find='Exterior ', replace='') -%}
                  {%- set name = name | regex_replace(find=' Light', replace='') -%}
                  {%- set name = name | regex_replace(find=' Mains', replace='') -%}
                  {%- set name = name | regex_replace(find='s 3x', replace='') -%}
                  {%- set name = name | regex_replace(find=' 1x', replace='') -%}
                  {%- set name = name | regex_replace(find='Family Room ', replace='') -%}
                      'type': 'template',
                      'content_info': name,
                      'icon': 'mdi:lightbulb',
                      'icon_color': 'orange',
                      'content': name,
                      'entity': entity.entity_id
                {%- endfor %}
and the full dashboard yaml (using custom:auto-entities + custom:mushroom-chips-card ):
        cards:
            show_empty: false
            card_param: chips
            card:
              alignment: left
              tap-action:
                action: more-info
            filter:
              template: |
                      'type': 'template',
                      'content': name,
                {%- endfor %}
            sort:
              reverse: false
end result (at the top are the chips and names shorter/cleaner!):
The pattern in regex_replace can contain multiple strings.
  {%- set name = entity.name | regex_replace('Exterior|Family room| ?Light| ?Mains|s 3x| ?1x', '') | trim -%}
      'type': 'template',
      'content': name,
{%- endfor %}
Copy-paste it into the Template Editor and confirm the generated names are correct. Let me know if it produces anything undesirable (like double spaces within the name) and I’ll adjust the regex pattern.
