Trust ZYCT-202 setting up dimming via zigbee2mqtt
Hi, you can check out ControllerX for this. It is a project I have been working on. You can also find a topic on the forum in here.
I believe you are the same that sent me an email, I currently not support this device, but the only thing I need to know is all the states/events that the controller can fire, so I can give as much functionality as possible. If those are the only states, you will be able then to:
  • Turn on/off the light
  • Change brightness when holding
I assume that “on” and “off” are only sent when clicking and not holding. If there was a holding event for on/off then I would be able to integrate the controller so it can change the color or the color temperature as well. And then I also assume that the brightness up/down also fires up when holding and it always sends the stop (no matter if you press or hold).
Let me know about all the events and I will integrate the controller asap.
Thanks,
Xavi M.
