Hello all,
I have configured DuckDns plugin consulting official guidelines in order to make my HA instance accessible from internet.
That works great. Now I want to setup trusted_networks(Authentication providers) for my LAN to allow login without authentication.
I have updated my HA configuration based on the docs.
Now the issue. trusted_networks
works when accessing HA from LAN address of HA host but not from duck dns url.
I understand that when I access the duckdns url, NAT translates my client’s internal ip to my ISP address which is not whitelisted.
But how I can achieve my initial goal, that is to enable passwordless login from my LAN when accessing HA from duck dns url?
Ever figure this out? I have the same question.
Can you show your trusted_networks configuration? I have this set and it does work fine. But then I also have trusted_proxy and x_forwarded_for so my real IP address is revealed to HA so maybe that makes it work.
Hi David,
If I use auth_providers I cannot access my HA locally. Not sure why? Maybe because its not encrypted locally? I type “http://192.168.1.101:8123” into my browser but I get, “This page isn’t working”.
Here is what I have in my configuration.yaml:
homeassistant:
latitude: !secret lat
longitude: !secret long
elevation: 16
unit_system: imperial
time_zone: America/Chicago
customize: !include customize.yaml
auth_providers:
- type: trusted_networks
trusted_networks:
- 192.168.1.0/24
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
base_url: https://xxxxxxxx.duckdns.org:8123
You might also need homeassistant auth provider I think.
I do use a reverse proxy but my config has:
auth_providers:
trusted_networks:
- 127.0.0.1
- ::1
- 10.90.11.0/24
- fd00::/8
- !secret zerotier_network
- !secret my_ipv6_network
trusted_users:
127.0.0.1: !secret user_id
"::1": !secret user_id
10.90.11.0/24: !secret user_id
"fd00::/8": !secret user_id
!secret trusted_ipv6: !secret user_id
!secret zerotier_network: !secret user_id
allow_bypass_login: true
- type: homeassistant
http:
# ssl_certificate: /ssl/fullchain.pem
# ssl_key: /ssl/privkey.pem
use_x_forwarded_for: true
trusted_proxies:
- 127.0.0.1
- ::1
ip_ban_enabled: true
login_attempts_threshold: 5
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
base_url: https://xxxxxxxx.duckdns.org:xxxxx
BTW I think you’re guaranteed to not be able to use the local IP address with your config. Your router also needs to support NAT loopback. A reverse proxy like Caddy will let you use the domain or ip address.
