I try to use trusted networks to skip / bypass authentication for clients, as I only have one (administrative) user setup and share my Home Assistant with all other family members equally. It’s not exposed to public anyhow.
Thing is, I cannot make this work. Here’s the relevant configuration excerpt:
192.168.78.0/24 is my actual network ip mask. I have Home Assistant running in a Docker container on a dedicated host, using Docker compose to front it with a Nginx based reverse proxy. The HA container is using host-network (otherwise discovery does not work) while nginx is running in a Docker network
Still, when accessing the HA frontend via NGinx from within my network, I am asked to authenticate, because my “Computer is not on the whitelist”. Funny thing is when accessing it using native port 8123, authentication is skipped.
How can I solve this or at least - how can I make HA log more information on the authentication process?
Yeah, it might sound strange, but it is a common setup. You put an application service behind a reverse proxy to introduce caching and scalability and increase security. Actually I’d like to see HA running “undercover” in Docker, but I need to connect it to the host’s network to make discovery work.
Now, back to the topic, where’s my fault, what are the options?
I might be running into the same issue. Are you saying the issue is a result of running behind a reverse proxy?
I tried directly accessing my HA instance (also running in docker) skipping the proxy and it still doesn’t work.
I wish the logs would output what ip it thinks the request is coming from.
Could be that this issue is actually related to my attempt of running HA after a reverse proxy. When accessing it directly on port 8123, the issue is gone.
