TRV and open window
Hello
I’m just starting with TRVs. Currently I have a few moes ones (zigbee).
I want to ask you to help with my doubts related to suspending heating by opened window.
AFAIK TRV recognizes opened window by temperature drop, disabling heating for some preconfigured time interval. HOW TRV knows the window got closed, since there is heating disabled (hence temp cannot grow up)? maybe it enables heating after the interval regardless window is open or not?
At this point I would like to clarify what does disabling heating mean. Does TRV close radiator? or just sends message to boiler to disable heating.
This question come in mind when reading various blueprints descriptions: opening window disables heating. But what if I want to heat in the rest of the house, while having opened window in single room?
Which leads to another question. I have window sensor on all windows. How can I implement them to support TRVs? the latter usually have no input like “window open - suspend heating”. Should in such case an automation lower temperature or maybe switch it to eco mode (which is set to lower target temperature)
Thank you in advance
