Hi all, it’s the same topic again…
I went through number of topics about automation loops, automation triggering themselves, endless loops, etc., but each one of those seemed to have a bit different issue, some different approach to solve the issue, or - the problem stated was solvable in a simpler way.
I am stuck with my idea. I have a TRV automation in mind, for which I need multiple modes and extra behavior. I tried to simplified my exact case to show the issues I struggle with, I hope I didn’t cut too much.
That’s the idea:
- in a room, there is one TRV device
- heating in a room has 2 modes: comfort and eco
- solution has an UI controls:
- mode selector, selecting mode sets an appropriate temperature
- temperature for each mode
- I have a “normal” users in house, so I want a TRV knob to function as well
- whenever a knob is turned, a comfort mode should be set as active and the set point of temperature from the TRV should be set as comfort mode’s temperature: this guarantees a master, manual override
This type of scenario, of “synced” states, without a possibility to differentiate the type of event (physical knob was turned vs it’s my automation that sets the TRV’s set point) leads into cyclic automation triggering. I can’t work it out.
- imagine being in a “comfort” mode
- user in UI sets mode “eco”
- automation sets the TRV’s set point to eco temperature
- but, a call of this service triggers the TRV state change, which we watch and understand as a physically turned knob…
- … which changes mode back to comfort
- this triggers the TRV’s temperature setting
- … and finally, thanks to couple of ifs, the oscillations stops…
Here is the current state of automation:
input_number:
dev_trv_comfort_temp:
name: "Comfort Temperature"
min: 5
max: 35
step: .5
initial: 22
unit_of_measurement: °C
icon: mdi:thermometer
mode: box
dev_trv_eco_temp:
name: "Eco Temperature"
min: 5
max: 35
step: .5
initial: 15
icon: mdi:fire
mode: box
input_select:
dev_trv_mode:
icon: mdi:car-cruise-control
initial: "comfort"
options:
- "comfort"
- "eco"
automation:
- id: dev_trv_mode_changed_to_comfort
alias: "DEV: TRV: mode_changed_to_comfort"
mode: queued
- platform: state
entity_id: input_select.dev_trv_mode
to: "comfort"
variables:
set_temp: "{{states('input_number.dev_trv_comfort_temp')}}"
- service: climate.set_temperature
entity_id: climate.dev_trv_thermostat
temperature: "{{set_temp}}"
hvac_mode: heat
- id: dev_trv_mode_changed_to_eco
alias: "DEV: TRV: mode_changed_to_eco"
mode: queued
- platform: state
to: "eco"
variables:
set_temp: "{{states('input_number.dev_trv_eco_temp')}}"
hvac_mode: heat
- id: dev_trv_device_temp_changed
alias: "DEV: TRV: device_temp_changed"
mode: queued
- platform: state
attribute: temperature
variables:
set_temp: "{{trigger.to_state.attributes.temperature}}"
- if:
- condition: template
value_template: >
{{states("input_select.dev_trv_mode") != "comfort"}}
then:
- service: input_select.select_option
option: "comfort"
- if:
value_template: >
{{states("input_number.dev_trv_comfort_temp") != set_temp}}
then:
- service: input_number.set_value
entity_id: input_number.dev_trv_comfort_temp
value: "{{set_temp}}"
- id: dev_trv_ui_mode_temp_changed
alias: "DEV: TRV: ui_mode_temp_changed"
mode: queued
- platform: state
variables:
set_temp: "{{trigger.to_state.state}}"
mode_updated: comfort
- platform: state
entity_id: input_number.dev_trv_eco_temp
variables:
mode_updated: eco
condition:
- and:
value_template: >
{{states('input_select.dev_trv_mode') == mode_updated}}
value_template: >
{{state_attr("climate.bdrm_trv", "temperature") != set_temp}}
hvac_mode: heat
The 2 first automations could be one, those are split for another reasons.
So, how to make it working?
How to keep in sync these entities together without triggering itself?
How can I differentiate the cause/context of what caused a different trigger. How to determine when I change the input_select.dev_trv_mode
internally due to state integrity of my automation, and it’s not a change caused by a real user? I did read a bit about context, but got into a conclusion it’s not reliable.
In my mind this type of goal should be achievable by HA user without a custom integration and I bet I just deadlock in a thought process. I did currently worked around the issues with a dirty fix, which I don’t like, as it breaks a “queue” mode. I would like to not share it, to not spoil the answers.
Help appreciated!
