hello, i would better understand the potentiality of the binding functionality over zigbee to setup some automatism without the intervention of home assistant.
for example: a Philips dimmer can be bind direct to a hue lamp to control it directly, that is correct?
what is the limit of the binding? for example is possible to bind a zigbee TRV valve to a zigbee relay ( to close the heater contact ) so the valve can control it directly?
if so, it is possible to bind multiple TRV valve to a single relay ( with OR logic ) ?
