Hello everyone. This is my first post on this forum. I hope you can help me solve my problem.
I started playing around with HA and trying to integrate thermostats with Tuya Local. I managed to integrate switches and door sensors, but the thermostats were beyond me. They are one of the most popular WiFi-enabled thermostats on AliExpress, the TRV604 with an OLED display.
During the thermostat configuration, I can select it from the list, so it connects to my Tuya account. After selecting it from the list, I have to wait while it detects the local address. After waiting, I get a window with the Device ID, IP address or host name, Localkey, and Protocol version. All information is filled in except for the IP address. I also receive the message âUnable to connect to your device with those details. It could be an intermittent issue, or they may be incorrect.â I checked the key and ID with the Tuya Developer portal, and everything is correct. I checked the IP address on the router and entered it manually, and the same result. P.S. Integration with Tuya works without any problems, but I would like to disconnect myself from the internet. ![]()
