Hello, I use the local tuya integration for some devices such as covers and temperature sensors, everything works correctly, but I can’t configure (SET) the brightness of a weather station lcd, if I send the command to modify via iot tuya platform or from its app it works, but I can’t from home assistant,
the DPid is 106 (lcd_brightness) and the possible values are 0,1,2,3
when I open the entity to set the value I see the number changing when using app or phisical button on device or send command via iot platform but if I move the slider here nothing happens.
what am I doing wrong? thanks
