Trying to access a sensor web-page using generic IP camera platform - help needed
I am trying to access WiFi sensor web-page in order to obtain ready made temperature graphic. I got the following error:
Log Details (ERROR)
Mon Jan 14 2019 19:36:30 GMT+0200 (Itä-Euroopan normaaliaika)
Error getting new camera image: Response payload is not completed
The web-page source code contains following lines:
RakuTemp html * { font-family: Arial; } RakuTemp
You may want to config the wifi connection, refresh this page or update the firmware.
You are connected through the wifi network: koivulehto
My configuration is the following:
group:
  default_view:
    view: true
    icon: mdi:home
    entities:
      - group.rakutemp
  rakutemp:
    name: Takan lämpötilat
    control: hidden
    entities:
      - camera.takka
camera:
  - platform: generic
    still_image_url: http://192.168.1.86
    username: xxxxxxx
    password: yyyyyyy
    auhentication: basic
    content-type: text/html
Update: the web-page source code is as the following:
<html><head>
<!DOCTYPE html><html><head><title>RakuTemp</title>
<script src='Chart.bundle.min.js'></script>
<style>
html * {
  font-family: Arial;
</style>
<script>
var waitingForData = false;
var numData1 = 0;
var dataIdx1 = 0;
var numData2 = 0;
var dataIdx2 = 0;
//var numChunks = 0;
var chunkIdx1 = 0;
var chunkIdx2 = 0;
var numData1Added = 0;
var numData2Added = 0;
var MAX_SAMPLES = 2048;
var connection = new WebSocket('ws://'+location.hostname+':81/', ['arduino']);
connection.binaryType = 'arraybuffer';
var s1 = new Uint16Array(MAX_SAMPLES);
var s2 = new Uint16Array(MAX_SAMPLES);
connection.onopen = function () {
  connection.send('Connect ' + new Date());
connection.onerror = function (error) {
  console.log('WebSocket Error ', error);
connection.onmessage = function (e) {
  console.log('onmsg type: ', typeof(e.data));
  console.log('onmsg data: ', e.data);
  if (typeof(e.data) == 'object') {
    var data = e.data;
    var dv = new DataView(data);
    /*var idx = dataIdx1 - numData1;
    if (idx < 0) idx += MAX_SAMPLES;
    for (var n=0; n<numData1; n++) {
      var tmp = dv.getUint16(idx*2, true);
      console.log("idx " + idx + ": " + tmp);
      if (++idx >= MAX_SAMPLES) idx = 0;
    if (chunkIdx1 < MAX_SAMPLES) {
      for (var n=0; n<MAX_SAMPLES/2; n++) {
        s1[chunkIdx1++] = dv.getUint16(n*2, true);
    else {
        s2[chunkIdx2++] = dv.getUint16(n*2, true);
    if (chunkIdx2 == MAX_SAMPLES) {
      console.log('All data received');
        cfg.data.labels.push(numData1Added);
        cfg.data.datasets[0].data.push(s1[idx]);
        numData1Added++;
      myChart.update();
      idx = dataIdx2 - numData2;
      for (var n=0; n<numData2; n++) {
        cfg2.data.labels.push(numData2Added);
        cfg2.data.datasets[0].data.push(s2[idx]);
        numData2Added++;
      myChart2.update();
  if (typeof(e.data) == 'string') {
    var tmp = e.data.split(' ');
    if (tmp[0] == "D") {
      waitingForData = true;
      cfg.data.labels = [];
      cfg.data.datasets[0].data = [];
      dataIdx1 = parseInt(tmp[1]);
      numData1 = parseInt(tmp[2]);
      dataIdx2 = parseInt(tmp[3]);
      numData2 = parseInt(tmp[4]);
      chunkIdx1 = 0;
      chunkIdx2 = 0;
      var _max = parseInt(tmp[5]);
      console.log('MAX_SAMPLES - ESP: ' + _max + ' WEB: ' + MAX_SAMPLES);
    else {
      //console.log('Server: ', e.data);
      var _temp = parseInt(tmp[0]);
      var _millis = parseInt(tmp[1]);
      if (waitingForData) {
      else {
        console.log(_temp);
        document.getElementById('a').innerHTML = _temp;
        if(cfg.data.datasets[0].data.length == MAX_SAMPLES){
          cfg.data.datasets[0].data.shift();
          cfg.data.labels.shift();
        cfg.data.datasets[0].data.push(_temp);
        numData1Added++;
        myChart.update();
        if (tmp.length > 2) {
          if(cfg2.data.datasets[0].data.length == MAX_SAMPLES){
            cfg2.data.datasets[0].data.shift();
            cfg2.data.labels.shift();
          cfg2.data.datasets[0].data.push(_temp);
          numData2Added++;
          myChart2.update();
</script></head><body>
<center style='font-size: 200%;'>
RakuTemp <b><span id='a'></span></b><br/>
<canvas id='myChart' width='400' height='240'></canvas>
<canvas id='myChart2' width='400' height='150'></canvas>
</center><br/>
<script>
var ctx = document.getElementById('myChart');
var cfg = {
    type: 'line',
    data: {
        labels: [],
        datasets: [{
            radius: 0,
            backgroundColor : 'rgba(243,134,48,0.5)',
            borderColor : 'rgba(243,134,48,1)',
            borderWidth : 2,
            label: '68min',
            data: []
    options: {
      scales:
            xAxes: [{
                display: false
var ctx2 = document.getElementById('myChart2');
var cfg2 = {
    type: 'line',
    data: {
        labels: [],
        datasets: [{
            radius: 0,
            backgroundColor : 'rgba(167,219,216,0.5)',
            borderColor : 'rgba(167,219,216,1)',
            borderWidth : 2,
            label: '17h',
            data: []
    options: {
      scales:
            xAxes: [{
                display: false
var myChart = new Chart(ctx, cfg);
var myChart2 = new Chart(ctx2, cfg2);
</script><p>You may want to <a href='/wifi'>config the wifi connection</a>, <a href='/'>refresh this page</a> or <a href='/update'>update the firmware</a>.</p></body></html><p>You are connected through the wifi network: koivulehto</p>
