Trying to access Node RED Web Interface without success
I’m running in circles trying to get my Hassio inside Proxmox running. I have pretty much basic setup with DuckDNS, NGINX Proxy, Mosquitto and Node RED addons. I tried without DuckDNS and NGINX earlier and it was working. As soon as I setup DuckDNS addon it breaks NodeRED after restart. Something must have changed since 0.89 that breaks it and since I can’t restore my backup from RPI3 I need to set it up from scratch with the latest version of HA.
I can reach my Hassio from the following locations:
  • locally from 192.168.1.7:8123
  • externally from my duckdns address
No matter what I do I just can’t open Node RED Web Interface
My Hassio config looks like this:
#     Home Assistant Main Configuration File      #
homeassistant:
  temperature_unit: C
  time_zone: !secret timezone
  latitude: !secret latitude
  longitude: !secret longitude
  elevation: 38
  unit_system: metric
  auth_providers:
    - type: legacy_api_password
      api_password: !secret api_password
    - type: trusted_networks
      trusted_networks:
         - 192.168.1.0/24
         - 172.30.0.0/16
  customize: !include customize.yaml
  whitelist_external_dirs:
  - /share
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
  base_url: !secret hassio_address
# Discover some devices automatically
discovery:
# Sensors
  # Weather prediction
  - platform: yr
# Text to speech
tts:
  - platform: google
group: !include groups.yaml
script: !include scripts.yaml
Here is my Node Red Addon config and the Log:
  "credential_secret": "!secret node_red_credential",
  "dark_mode": false,
  "http_node": {
    "username": "",
    "password": ""
  "http_static": {
    "username": "",
    "password": ""
  "port": 1880,
  "ssl": true,
  "certfile": "fullchain.pem",
  "keyfile": "privkey.pem",
  "require_ssl": true,
  "system_packages": [],
  "npm_packages": [],
  "init_commands": []
My Hassio System Log:
19-04-08 13:17:27 INFO (MainThread) [hassio.core] Hass.io is up and running
19-04-08 13:17:34 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-08 13:17:34 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-04-08 13:17:34 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
19-04-08 13:17:34 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request running
19-04-08 13:17:52 INFO (MainThread) [hassio.auth] Auth request from a0d7b954_nodered for redacted
19-04-08 13:17:52 WARNING (MainThread) [hassio.auth] Wrong login from redacted
19-04-08 13:18:09 INFO (MainThread) [hassio.auth] Auth request from a0d7b954_nodered for redacted
19-04-08 13:18:09 WARNING (MainThread) [hassio.auth] Wrong login from redacted
19-04-08 13:18:18 INFO (MainThread) [hassio.auth] Auth request from a0d7b954_nodered for redacted
19-04-08 13:18:18 WARNING (MainThread) [hassio.auth] Wrong login from redacted
19-04-08 14:07:31 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
And Home Assistant log:
2019-04-08 13:17:15 WARNING (MainThread) [homeassistant.components.http.auth] legacy_api_password support has been enabled.
2019-04-08 13:17:16 ERROR (MainThread) [homeassistant.components.device_tracker] Unable to load /config/known_devices.yaml: Config file not found: /config/known_devices.yaml
2019-04-08 13:17:52 ERROR (MainThread) [homeassistant.components.hassio.auth] Can't find Home Assistant auth.
2019-04-08 13:18:09 ERROR (MainThread) [homeassistant.components.hassio.auth] Can't find Home Assistant auth.
2019-04-08 13:18:18 ERROR (MainThread) [homeassistant.components.hassio.auth] Can't find Home Assistant auth.
2019-04-08 13:18:49 WARNING (MainThread) [homeassistant.components.http.view] Access from trusted networks without auth token is going to be removed in Home Assistant 0.96. Configure the trusted networks auth provider or use long-lived access tokens to access /api/services/script/turn_on from 172.30.33.2
I don’t know how to resolve this, I have wasted three days trying to find solution online without success. When I check config it’s OK.
Any help?
