Currently I am trying to modify my garden group in a way that it shows the sensors as badges, which should be supported from custom-ui (https://github.com/andrey-git/home-assistant-custom-ui).
Installation of the ui components seems to have worked as I see the following:
and
I tried to configure the custom-ui in the following way:
customize_glob:
custom_ui_state_card: custom-ui
group.tracked_devices:
state_card_mode: badges
group.garden:
groups:
ground_floor:
view: yes
entities:
- group.living_room
- group.garden
garden:
entities:
- sensor.dht_221_esp_garden_temperature
- sensor.dht_221_esp_garden_humidity
- sensor.dht_221_esp_garden_voltage
And the result is the following:
I would have expected that the red part were badges instead of the default view. Maybe someone can give me a hint were I could make a change in my config to get the badges to show in the red area.
