Trying to add Hive integration
Sorry I’m new to HA so I’m trying to find my way around.
I want to add my Hive as a temperature sensor to HA but I’m struggling to figure out how I can add the integration. When I click on new integration and type “Hive” nothing is found. Im using HA v0.103.5
Did you read the documentation?
I’m not sure what the solution is here, all it says it to ensure you have the following in your configuration.yaml
# Example configuration.yaml entry
hive:
  username: YOUR_USERNAME
  password: YOUR_PASSWORD
I’ve added this, when I go into Integrations however, Hive is not listed as an item.
You didn’t mention that in your original post which was why I asked.
Did you restart HA after adding that to your configuration?
Are you using the US version or U.K. version of Hive?
At the moment the US version is not supported, but we are working on it.
I think there was a parsing error in the config file, corrected it an all is well. Thanks for your help.
