Trying to add slimmelezer integration (esphome)
Hello everyone,
I had to reinstall my whole home assistant instance on TrueNAS, so I had the true charts version.
Now I can’t get my integration working because it keeps throwing me an error, which is making me nuts.
Logs:
Logger: aiohttp.server
Source: /usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py:421
First occurred: 8:02:35 PM (3 occurrences)
Last logged: 8:03:08 PM
Error handling request
File “/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py”, line 452, in _handle_request
resp = await request_handler(request)
File “/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py”, line 543, in _handle
resp = await handler(request)
File “/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py”, line 114, in impl
return await handler(request)
File “/usr/src/homeassistant/homeassistant/components/http/security_filter.py”, line 91, in security_filter_middleware
File “/usr/src/homeassistant/homeassistant/components/http/forwarded.py”, line 100, in forwarded_middleware
File “/usr/src/homeassistant/homeassistant/components/http/request_context.py”, line 28, in request_context_middleware
File “/usr/src/homeassistant/homeassistant/components/http/ban.py”, line 80, in ban_middleware
File “/usr/src/homeassistant/homeassistant/components/http/auth.py”, line 235, in auth_middleware
File “/usr/src/homeassistant/homeassistant/components/http/headers.py”, line 31, in headers_middleware
response = await handler(request)
File “/usr/src/homeassistant/homeassistant/components/http/view.py”, line 149, in handle
result = await handler(request, **request.match_info)
File “/usr/src/homeassistant/homeassistant/components/http/decorators.py”, line 72, in with_admin
return await func(self, request, *args, **kwargs)
File “/usr/src/homeassistant/homeassistant/components/config/config_entries.py”, line 185, in post
return await super().post(request, flow_id)
File “/usr/src/homeassistant/homeassistant/components/http/data_validator.py”, line 72, in wrapper
result = await method(view, request, data, *args, **kwargs)
File “/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py”, line 110, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 358, in async_configure
result = await self._async_configure(flow_id, user_input)
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 404, in _async_configure
result = await self._async_handle_step(
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 501, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File “/usr/src/homeassistant/homeassistant/components/esphome/config_flow.py”, line 92, in async_step_user
return await self._async_step_user_base(user_input=user_input)
File “/usr/src/homeassistant/homeassistant/components/esphome/config_flow.py”, line 71, in _async_step_user_base
return await self._async_try_fetch_device_info()
File “/usr/src/homeassistant/homeassistant/components/esphome/config_flow.py”, line 167, in _async_try_fetch_device_info
response = await self.fetch_device_info()
File “/usr/src/homeassistant/homeassistant/components/esphome/config_flow.py”, line 332, in fetch_device_info
zeroconf_instance = await zeroconf.async_get_instance(self.hass)
File “/usr/src/homeassistant/homeassistant/components/zeroconf/init.py”, line 142, in async_get_instance
return cast(HaZeroconf, (await _async_get_instance(hass)).zeroconf)
File “/usr/src/homeassistant/homeassistant/components/zeroconf/init.py”, line 157, in _async_get_instance
zeroconf = HaZeroconf(**zcargs)
File “/usr/local/lib/python3.12/site-packages/zeroconf/_core.py”, line 176, in init
listen_socket, respond_sockets = create_sockets(interfaces, unicast, ip_version, apple_p2p=apple_p2p)
File “/usr/local/lib/python3.12/site-packages/zeroconf/_utils/net.py”, line 358, in create_sockets
listen_socket = new_socket(ip_version=ip_version, apple_p2p=apple_p2p, bind_addr=(‘’,))
File “/usr/local/lib/python3.12/site-packages/zeroconf/_utils/net.py”, line 248, in new_socket
s.bind(bind_tup)
OSError: [Errno 98] Address in use
