I created a test grid with two cards for my dashboard. They both should perform the same function i.e. sending a command to my Google Assistant. The “area” card does it successfully, however the “button” card doesn’t work. What am I doing wrong or misunderstanding? Thanks for your help.
Have you tried removing the entity from the button card?
Yes. Same results.
