Trying to configure IFTTT, but HA says I'm not accessible from the internet
What does your base url look like?
Mine is this: https://my-domain.duckdns.org:xxxxx
I’m using a reverse proxy so I need to have the port xxxxx configured in the base url and then when I set up IFTTT it accepts it.
which port is the xxxx ? the one from the proxy (443 for me) or the one from HA (8123 for me) ?
i can connect to HA from 2 url:
if you use 443 then you shouldn’t need to include the port. I have one open port - that is xxxxx and the reverse proxy proxies that to 8123 for HA, 3218 for configurator etc. You will need to use the HTTPS one I believe, in your case https://homeassistant.domain.tld should work.
same error :frowning:
really i dont get it
i’ve found my problem,
before:
  http:
    base_url: !secret base_url
after:
http:
yaml synthax was wrong…
Thanks for your time !!!
Bloody Hell!!! spacing kills you every time huh?
Hi, can you point it out, I can’t find it …
Looking at that again now maybe it’s not as useful as I thought.
if I remember correctly you use caddy, right? I do too.
So in order to have it working your solution is as below?
http:
  api_password: !secret api_password
  base_url: https:xxx.duckdns.org:8123
  cors_allowed_origins:
    - http://192.168.1.11:7080
and in caddy file
   https://xxx.duckdns.org {
    tls  /ssl/fullchain.pem /ssl/privkey.pem   {
        alpn http/1.1
    proxy / 192.168.1.11:8123 {
        transparent
        websocket
    log stdout
    errors stderr
mmhhh not working for you?
Caddy
On Caddy you add the following to the proxy section(s) of your configuration:
header_upstream Authorization “Bearer YOUR_LONG_LIVED_ACCESS_TOKEN”
Alternatively, you can do the same in the header section if you want it for every page:
Authorization “Bearer YOUR_LONG_LIVED_ACCESS_TOKEN”;
Yes I use Caddy.
No I don’t use any of those except the base_url
No I don’t use the TLS or my own certificates. I let Caddy get LetsEncrypt certificates.
You asked me for that article so I found it and posted it for you.
Caddy is working perfectly for me even on IPv6 only (no IPv4). I have not added or used the long_lived_access_token.
I use only the normal HA auth with 2FA.
I tried as in my post and, so far, all is working. For anyone else that’s a working solution (443 port forwarded to 443 of the host hosting hass /Caddy)
