I’m trying to configure the IFTTT integration from the integrations tab on the configuration settings page, but I get the error, “Your Home Assistant instance needs to be accessible from the internet to receive IFTTT messages.”
Now strictly speaking, HA doesn’t know it actually is contactable from the internet, because I have access to it reverse proxied through nginx with an SSL frontend. It would be nice to be able to say, “Hey, you are actually accessible, please let me do this.” Or perhaps just allow me to tell the configuration the URL to use to get at HA.
Is there a way around this issue, or am I stopped dead? I’m using v0.80.0.
Created an account just to thank you for this response!
It’s something that’s obvious in hindsight, but I wasn’t having any luck figuring out what needed to be done to get this working. Maybe some help text or rewording to make it more clear this is necessary.
Thank you for your answer!
I tried the last option but it did not help as well. I am pretty sure that my config is correct (just uncommented the http part). The only idea I have is that maybe the apache proxy is messing it up? I have followed the https://www.home-assistant.io/docs/ecosystem/apache/ guide.
Whatever is in the browser address bar when you got the Hass website, minus the protocol specifier, that’s what goes in that config setting. I.e., hass.mydomain.com:8123.
If you’re using nginx, then put in the name of the URL that is accessible from outside the proxy.
I’m having the same issue.
I have my base_url set.
I have port 80, 443 and 8123 all forwarded to 8123.
If I try http://MYDOMAIN.duckdns.org/api/states/binary_sensor.TESTING I receive a 401: Unauthorized error so I know it’s accessable.
Other integrations do not report the Aborted error.
I noticed after a fresh install it actually tries and shows a spinning circle then after it fails it just instantly fails from then on.
I’m not interested in getting SSL to work until I know this will actually work.
I forwarded 80 to rule out variables. Can you confirm you actually need SSL or is that just a guess? I had issues getting SSL to work thus why I wanted to see if it was even necessary before I work through that.
Thanks for the suggestion, I tried that but same issue.
i’ve upgrade to 0.81.1 but same problem.
base_url is up from outside and reverse proxy is working just fine (i can connect to my HA instance from work)
