I am trying to use andrewjfreyers monitor bluetooth script, but i can’t seem to connect,
1546361073: New connection from 192.168.1.223 on port 1883. 1546361073: Socket error on client <unknown>, disconnecting. 1546361074: New connection from 192.168.1.223 on port 1883. 1546361074: Socket error on client <unknown>, disconnecting. 1546361081: New connection from 192.168.1.223 on port 1883. 1546361081: Socket error on client <unknown>, disconnecting.
Can anyone tell me why?
I have the mqtt preference file sent to my hassio ip address and this is the config in hassio
I was able to add my username and password, but now i am getting this error
1546361844: New connection from 192.168.1.223 on port 1883.
[INFO] found david on local database
1546361845: New client connected from 192.168.1.223 as mosqpub|14145-raspberry (c1, k60, u’david’).
1546361845: Client mosqpub|14145-raspberry disconnected.
I got rid of it, now my password doesn’t have, the !
but i am still getting an error
1546379032: New client connected from 192.168.1.223 as mosqsub|693-raspberrypi (c1, k60, u’david’).
1546379033: New connection from 192.168.1.223 on port 1883.
1546379033: New client connected from 192.168.1.223 as mosqpub|754-raspberrypi (c1, k60, u’david’).
1546379033: Client mosqpub|754-raspberrypi disconnected.
It appears to be a client issue i think, i tried to follow his guide to the tea, but no messages are going across and not connecting, same password and username (i’ll remove this once i get it figured out)
