Trying to connect Ecobee to home assistant with no success
I have two voice control ecobees. I am trying to connect them to home assistant.
The instructions that I have found say “You will need to obtain an API key from ecobee’s developer site to use this integration. To get the key, your thermostat must be registered on ecobee’s website”. They are registered.
Following those instruction and becoming a developer. The developer option is not on the site. I selected “My Apps” hoping this was the solution. Then I selected
“Add Application” It wants me to “Enter 4 character code” with the message
“Please enter authorization code that was provided by the application you installed”
In Home Assistant under configurations (Picking the +) and selecting “ecobee”
it wants the API key optained from ecobee.com
I am new to Home Assistant so please help and be gentle.
All help appreciated and be safe
Click the “Developer” button
You’ll get this screen. Fill out the information and you’ll get an API key from there.
From there follow the instructions as you have what you need.
Thanks a million. I thought I had registered as a developer, but I must have missed something. I tried again and the Developer showed up and I got the key.
Thanks your great
