Trying to connect the MAX6675 to a D1 mini, got 'invalid value' from sensor
Looking at the docs it says in the example:
spi:
  miso_pin: D0
  clk_pin: D1
  - platform: max6675
    name: "Living Room Temperature"
    cs_pin: D2
    update_interval: 60s
From that it needs three pins apart from 3.3v and gnd.
MISO
CLK
CS
Looking at the pinout for the D1 mini:
I guess CLK is SLCK?
I made my config like this:
esphome:
  platform: ESP8266
  board: esp8285
spi:
  miso_pin:GPIO12
  clk_pin: GPIO14
  - platform: max6675
    name: "Raclette Temperature"
    cs_pin: GPIO15
    update_interval: 30s
But it gives me this:
[W][max6675:040]: Got invalid value from MAX6675Sensor (0xFFFF)
Please help me with some insights…
This does not look like the correct board definition for a Wemos D1 mini.
esphome:
  platform: ESP8266
  board: esp8285
I use:
esphome:
  platform: ESP8266
  board: d1_mini
Also what pins have you connected the sensor board to as marked on the board (D1 - D8)?
Hi Tom
Ahh, yes, I can’t find the board type definitions, so I’m a bit blind there. I corrected it but no change.
I entered this in the code
MISO: GPIO12
CLK: GPIO14
CS: GPIO15
I’ve also tried
MISO: D6
CLK: D5
CS: D8
But that gave me the same result :cry:
Board definitions are here (ESP8266) and here (ESP32). Bookmark them. Clicking on your board type will take you to a page with the definitions.
I can see what pins you used in the code, I wanted to make sure you were physically connected to the correct pins. So I wanted the ‘D’ numbers on the board to see if they corresponded to the GPIO numbers you had in the code.
If you are connected to these:
MISO: D6
CLK: D5
CS: D8
Then that’s all good.
The MAX6675 works from 3 to 5V so supplying it from 3.3V is not an issue (do not use 5V, you need 3.3V logic on the other pins).
So I’m out of ideas. :man_shrugging: Sorry.
EDIT: is the thermocouple connected?
Ok, darned :grinning_face_with_smiling_eyes:
This is what is built at the moment…
DOOH, when looking at the picture I saw that I had put it to MOSI instead of MISO, darned, so I moved it and, taddaaa
Yes, it’s that hot in Denmark at the moment, pheew.
Ha! So that was a big ‘if’.
