Trying to create automation for ecobee but trigger using an Aqara sensor
So my son’s room is upstairs and gets really hot, but the ecobee is downstairs and it triggers when to go on and off based on it’s temperature at the device. I bought Aqara sensors for all 3 bedrooms upstairs, and I want the ecobee for the entire house (I know… I need a second zone) to go on and off based on his room’s temp.
Unfortunately the only automation I’ve successfully done is a motion sensor in the garage that turns on the garage lights… My sensor (which now looking at it could probably be renamed…) in play is
sensor.lumi_lumi_weather_64237c06_temperature
Hello, I suggest you do the following first-
  1. Change Aqara temperature entity name to something more familiar to you- such as sensor.temperature_bedroom_1, sensor.temperature_bedroom_2, and sensor.temperature_bedroom_3
  2. Get to know/change the climate’s entity name for each room- such as climate.bedroom_1, climate.bedroom_2, and climate.bedroom_3
Then, for your automation, you can use numeric_state as the trigger.
An example of the YAML code is as follows-
alias: Climate Control Bedroom 1
description: ''
mode: single
  - platform: numeric_state
    entity_id: sensor.temperature_bedroom_1
    above: '25'
    below: '18'
condition: []
  - choose:
      - conditions:
          - condition: trigger
        sequence:
          - service: climate.set_hvac_mode
              entity_id: climate.bedroom_1
              hvac_mode: cool
      - conditions:
        sequence:
          - service: climate.turn_off
    default: []
OR - Automation to anticipate server crashes/reboot made by Taras, written here
description: ''
mode: single
    above: 25
    below: 18
  - platform: homeassistant
    event: start
condition: []
  - variables:
      t: "{{ states('sensor.temperature_bedroom_1') | float }}"
  - choose:
      - conditions:
          - "{{ t >= 25 }}"
          - "{{ is_state('climate.bedroom_1', 'off') }}"
        sequence:
              hvac_mode: cool
      - conditions:
          - "{{ t <= 18 }}"
          - "{{ is_state('climate.bedroom_1', 'on') }}"
        sequence:
    default: []
@stringztoo Did you ever get this working? I’m trying to do the exact same thing.
