I have configured an Automation using a timer-helper, and this works very nicely.
I have now tried to extend the functionality by adding a illuminace sensor.
I have added a condition that is light level is below 100,… timer triggers and light comes on…
And yes this bit works,…
But I am now struggling to figure out how to re-trigger the timer when motion occurs if just the timer is still running.
ie motion + (light level <100 ) start timer
elseif motion + (timer still running ) restart timer…
As the illuminance sensor will be reading the new light level created by switched on light source. and not ignore the illuminance level whilst the timer is still running.
Can anyone help me as I cannot see how to rationalise my logic withing the confinds of extended building block of the graphic UI
Many tx
My Yaml code as follows:-
alias: Hallway with Light Level
description: ""
triggers:
- type: turned_off
device_id: d2c0315ec6da6d0d017c3086337821ce
entity_id: 86f919152a1f4d1b412c3bc0ab9a8279
domain: binary_sensor
trigger: device
- type: turned_on
trigger: device
- trigger: event
event_type: timer.finished
event_data:
entity_id: timer.light_timer_2
conditions:
- condition: numeric_state
entity_id: sensor.tas_eighteen_pir_veml7700_illuminance
below: 100
actions:
- choose:
- conditions:
- condition: trigger
id:
- Motion Stopped
sequence:
- action: timer.start
metadata: {}
data: {}
- conditions:
id:
- Motion Detected
sequence:
- action: timer.cancel
data: {}
- type: turn_on
device_id: b89aef7f901b43782ade25433492c9bc
entity_id: 21bc4f957104bb066acc8d9892164a0a
domain: light
- conditions:
id:
- Timer Finished
sequence:
- type: turn_off
domain: light
mode: single
